Valve timings
Old Nov 13, 2010 | 08:09 AM
Gaggenau's Avatar
Gaggenau is on a distinguished road
Valve timings
So i came a cropper of the CCT failure again!!! and decided to get some APE's
So this morning i tried to hand turn the engine over to put the front in to TDC and heard a "klink klink"...crap
I put the APE in the front cylinder and and then hand turned over the engine and felt smooth but just stopped at one point.
I assume that the "klink" noise i heard was the cam chain skipping teeth on the cam cogs
I guess it's possible to check the valve timings of the fron cylinder with out dropping the engne out, but how much of a PITA is it?
Old Nov 13, 2010 | 09:04 AM
mboe794's Avatar
It's not too bad. I assume you already have access the the front CCT. Then the oil cooler needs to move. And I think it helps to remove the left radiator. Which means draining some coolant and the fairings have to come off too. Then it's just a matter of working in a cramped space.
Old Nov 13, 2010 | 12:03 PM
Gaggenau's Avatar
Yea i have the tank and airbox off to get to the front CCT allready, dosent sound to bad then, i thought it might be a case of moving the oil cooler and taking the fairings off. Thanks
Old Nov 13, 2010 | 12:54 PM
Syclone's Avatar
Boosted
Fairings need to come off, oil cooler moves ahead. I did mine without removing any radiators.
Old Nov 20, 2010 | 09:21 AM
Gaggenau's Avatar
Well i got it sorted today, had to get a bit of help with sorting the timing.
Tomorrow i'll put the front cover on, bolt back the oil cooler and radiator (neither of them i had to reove, just un-bolted and moved) fairing and tank and fire her up
superman_006
Jul 24, 2010 10:17 PM
Dave Wicks
Mar 15, 2007 05:37 AM
Alan
Jan 19, 2007 10:20 AM
J.J.
Nov 6, 2006 03:55 PM
dpenix76
Nov 2, 2006 04:03 AM
