Upgrading fork internals
Old Sep 12, 2008 | 11:57 AM
zmaniv's Avatar
Ok i tried to search but came up with squat.
If I upgrade the fork springs should I do the racetech gold valves? Should I do the rebound valves as well?
Size wise I am over 220 without gear. I don't want to have my front end wash out like I did on my F2.
Old Sep 12, 2008 | 07:04 PM
joshn569's Avatar
joshn569 is on a distinguished road
I dont know what else is out there besides springs, but if you can find more let me know how it works out. I put in stiffer springs and 10w oil, then went to 7w and was happy with that.
Old Sep 13, 2008 | 12:39 AM
shayne's Avatar
The VTR forks have two problems, spring rate, and valving. In my opinion, I would not go to the trouble of removing and disassembling the forks without doing both at the same time. Gold Valves is a Racetech brand name and will do the job for you in conjunction with the correct springs for your weight.
If you want a full job, the shock needs valving too. Spring is ok for anyone who weighs up to about 95kg.
Old Sep 13, 2008 | 05:15 AM
SlowHAWK's Avatar
Springs a valves are a very common upgrade. There is a rebound modification you can make instead of buying the racetech kit (Search rebound need mod).... although many people are completely satisfied with just the correct spring and the valves.
J.
yruyur
Jan 22, 2012 07:45 PM
J dub
Nov 12, 2011 09:24 AM
stebbdt
Sep 8, 2010 09:20 AM
mikstr
May 24, 2010 11:34 AM
faz
Sep 13, 2006 08:09 PM
