UH OH!!
Old Jan 17, 2013 | 07:52 PM
Hopey's Avatar
Hopey is on a distinguished road
UH OH!!
I just tore my rear end off my bike to install my new Jamie D shock(tips from the forum)then put it all back together and realized I put the resivoir on the chain side( I had it dangling there)****! Now I would like some reassurance it will be OK,or do I have to go back in there and reverse it? Oh and I did that cause the way rebound screw was positioned, it had to be that way so I could adjust without interference from the header.Thanks in advance. Hopey
Old Jan 17, 2013 | 08:02 PM
That is the side Ohlins has you put it on, so you should be ok.
Old Jan 17, 2013 | 08:10 PM
Hopey's Avatar
Phew!Thanks for the reply.Nice bike ,by the way.
Old Jan 17, 2013 | 08:36 PM
Why did you think it wouldnt be ok? Chain heat? Noise? Balance issue? Save the whales? What?
Old Jan 17, 2013 | 08:41 PM
If you throw the chain you can take out the reservoir but that was more in the old days...
Old Jan 17, 2013 | 09:10 PM
Hopey's Avatar
Thought it would be a problem because of the close proximity to the chain guard ,when hung on the underside of the bottom rail of the seat stay.Just cause I thought it looks better there.I guess the only time it would contact there is when I'm in the whoppity do's. P.S.glad you guys were still awake to help me out
