surging at idle
Old Aug 12, 2008 | 06:56 PM
Erik S.'s Avatar
surging at idle
Ok, before I take this to a "mechanic" of any sort, I figured I'd try to use the best resource available to me, this bulletin board.
My SH, a 2000 with about 17K on it, is surging. Steady idle around 1100 RPM, then it drops to about 900, then back to 1100-1200. Might steady out for a 30-60 seconds then does it. Seems random, not rhythmical.
I put Seafoam in this last tank to see if something had gummed up a carb, no noticeable difference.
All stock, no pair mod, no K&N, Jardine High mounts.
Any and all help is appreciated.
Erik
Old Aug 12, 2008 | 07:06 PM
shayne's Avatar
Start with the basics, and do a carb synch, and check the mixtures and idle speed. Worth looking at your plugs and airfilter too.
Old Aug 13, 2008 | 06:26 AM
Erik S.'s Avatar
Thanks Shayne, that is the direction I was going to head. Just wanted to make sure that i wan't missing something specific to the SH.
Old Aug 14, 2008 | 04:56 AM
shayne's Avatar
I have found my VTR to be quite touchy when it come to the carb synch and so on. It needs to be right more so than other engines I have worked on. So this is always a good place to start.
thedeatons
Jun 21, 2015 09:11 PM
raptorrider
May 19, 2010 11:33 AM
Anto
Aug 20, 2008 05:27 PM
DaxMiddler
Apr 28, 2006 03:22 AM
hawkoneup
Sep 2, 2005 09:18 PM
