Stupid rear brake..
Old May 31, 2010 | 01:14 PM
t-dogg's Avatar
Stupid rear brake..
So, my rear brake keeps on locking up randomely after riding for a while. I never use the rear brake. Im pretty sure I broke the the threaded part that goes into the rearset brake lever off the master cylinder, so i just left it loose, so i dont see how the brake pads can lock up if the brake lever doesnt work. Could it be vibration or heat causing it??
Old May 31, 2010 | 04:29 PM
Crashrat's Avatar
Maybe gunk in the line or something? It seems like my M2 used to do something like this before I rebuilt the master. Of course, then something else went wrong with it
CR
Old May 31, 2010 | 05:05 PM
jay956's Avatar
air in the line or dirty piston
Old May 31, 2010 | 05:47 PM
residentg's Avatar
Originally Posted by t-dogg
...Im pretty sure I broke the the threaded part that goes into the rearset brake lever off the master cylinder, so i just left it loose...
I'd start by fixing this and see if it solves the problem.
Old May 31, 2010 | 06:48 PM
SPRHK's Avatar
my e-penis is huge!!
SPRHK is an unknown quantity at this point
there could be 2 reasons for this.
#1- MC isnt returning fluid to the resevoir because of a plugged return orifce.
#2- Caliper seals have gunk built up, not allowing the piston to retract properly. Heat builds up from pad friction, creating the condition.
Either way, disassemble the rear brake system, clean and replace the seals.and replenish with clean fresh fluid.
Old May 31, 2010 | 10:27 PM
I had a simmilar issue a while back. I put new pads on the rear wheel and it would start to drag after being ridden a few miles. It turned out the problem was the "slide" bolts for the rear caliper were seized not allowing the caliper to move side to side. The pads didn't have enough clearance and would expand from the heat... turned the rotor a pretty blue too.
Old Jun 1, 2010 | 01:09 PM
t-dogg's Avatar
Yeah I turned my rotor some crazy colors also. Locked up this weekend and for some reason I decided to take my glove off and touch the rotor. My fingers are now a pretty red color. I guess I'll take the the whole thing off disconnect it and drain it. Is it possible to get the threaded part off the mc or would I have to get a whole new one?
Old Jun 1, 2010 | 01:24 PM
I've got a good master cylinder from a 2001 I'll throw into the rotor box. Just bump up the shipping to $26.78 as it will put it over the next pound
Old Jun 2, 2010 | 01:04 PM
t-dogg's Avatar
Inderocker=Bad *** Seller!
smokinjoe73
Jan 1, 2014 11:46 AM
superhawkfanboy88
Aug 30, 2012 11:38 PM
dshakes
Apr 26, 2010 05:34 PM
B R
Nov 8, 2006 11:38 PM
seattlesucks
Jun 28, 2006 12:35 PM
