strategies for adjusting idle mixture screws with carbs on bike
Old Jun 5, 2012 | 01:04 PM
blamecanada's Avatar
blamecanada is on a distinguished road
title says it all....those of you who adjust them with it carbs on the bike, what tools do you use?
they're slotted on my bike (thanks speedkelly) but I don't have any screw driver or tool I can fit in there with my hand.
adjusting them off the bike is unacceptably slow/inaccurate...
edit: google is my friend? found that motionpro screw driver...going to be useful for other crap I do on european cars as well so I went ahead and ordered one
Old Jun 5, 2012 | 01:50 PM
speedkelly@aol.com's Avatar
Pixe's? Little Irish leprechaun folks. Very small childern (kind of like Nike slave labor?)
Idea's ???
Attach a slotted screwdriver bit to a thimble place on pinkie and turn??
Good luck! no really?
Old Jun 5, 2012 | 04:02 PM
BeerHunter's Avatar
Slacker
You should like the MotionPro tool, I am happy with mine. I had another bike (inline 4) so it was very useful.
The tool will also help to make carb synch adjustments. It includes a 1/4 square drive socket adapter. Plug in a 7mm? socket and it works quite well for the synch screw.
Old Jun 5, 2012 | 05:49 PM
GTS's Avatar
GTS
Seasoned tech
Yeah that Motion Pro tool is nice! I picked one up awhile back. I took the detent out of it as it kind of hampered the feel. The carb heater hoses are kind of in the way so I thought about getting rid of them next time I take the carbs off to make it easier to get to the screws. That kit also comes with the D shaped adaptor so you do'nt have to slot your screws.
Old Jun 5, 2012 | 05:53 PM
aja's Avatar
aja
Do you have a link to the tool you bought?
Old Jun 5, 2012 | 06:45 PM
Here is the only one that I think will work on our crazy carb dimensions. BUT you still gotta slot the screw with a dremmel fiirst.....Amazon.com: Motion Pro Pilot Screw Adjusting Tool 08-0119: Automotive
Before buying it I made this monstrosity from 1/4 sockets, a closed wrench, hose clamps and universal joints. It didnt quite work......But brilliant none the less
Attached Thumbnails strategies for adjusting idle mixture screws with carbs on bike-tool-004.jpg   strategies for adjusting idle mixture screws with carbs on bike-tool-002.jpg
Old Jun 6, 2012 | 02:30 AM
BeerHunter's Avatar
Slacker
The tool I have looks like this: Motion Pro 90 Degree 1/4" Hex Driver
When first purchased, the D shaped attachment was too fat and would not fit into the pilot screw bore. Some time spent with the bit in a drill, clamped on a vise (used like a lathe) and an angle grinder made the tool perform as it should.
Old Jun 6, 2012 | 05:15 AM
VTRumble's Avatar
I made one a few years ago using brake tubing. I put a 90 deg. bend in it, made a 1" piece with a d shaped crimp to fit the pilot. Then put a piece of speedometer cable through the bent tubing, and crimped the small piece on the end, then crimped another short piece on the other end to use as a handle. Worked great, I actually have to dig it out, since I just ditched the k&n and re-jetted. Total cost, about $5.
Old Jun 6, 2012 | 06:07 AM
Wow, beerhunter, for the $22 one I was willing to slot the screws (5 min job) but for $70 I woud've been very mad to have to do makeshift machine shop work to make it work.
Old Jun 6, 2012 | 08:57 AM
BeerHunter's Avatar
Slacker
I was not too happy about it either, but id does work very well now and is very useful for many other applications as well. In addition to the 5 included bits, you also can attach ANY 1/4 inch driver bit to the tool. I loves my tools.
The price is cheaper now than when I made the purchase years ago. I think I paid $100 for it back then.
Old Jun 6, 2012 | 09:50 AM
Yeah I have sort of a cheapness gene. I always believe I can do it cheaper (and better). I searched for a couple days on that tool.
Even with 5 bikes I didnt figure I would use it often enuff and have only had bad experience with those d-shaped screws. If it was a viable drive system you would see it everywhere. Its actually a tamper resistant screw.
I got one hawk perfect but still tinkering with the other. Its 2.5 turns out right?
Old Jun 6, 2012 | 11:49 AM
BeerHunter's Avatar
Slacker
I think 2.5 turns is a good starting point. I honestly do not know where mine are set since I tweak them until it runs perfectly. Pretty sure that the front is set a little leaner than the rear.
thedeatons
Jun 21, 2015 09:11 PM
Byrdman
May 5, 2009 06:29 PM
Speed_Demon
Feb 17, 2007 05:57 PM
DaxMiddler
Apr 28, 2006 03:22 AM
roadrun_fr
Aug 30, 2005 09:49 AM
