Sticking Headlight switch
Old Mar 5, 2013 | 03:03 PM
Highfly's Avatar
Highfly is on a distinguished road
Hi Does anyone have experience of the headlight high/dip switch sticking? First it was a bit sticky going frim dip to high beam or visa versa but now it is just stuck in dip beam.
Old Mar 5, 2013 | 03:34 PM
Wicky's Avatar
Yes, so got a new left switchgear unit.
Old Mar 5, 2013 | 11:09 PM
Yeah, take it apart, clean it with alcohol... Then fill it back up with vaseline...
DO NOT use wd-40 or various other stupid products... You only harm stuff...
Old Mar 6, 2013 | 11:30 AM
Highfly's Avatar
Thanks Tweety ill try that!
Old Mar 6, 2013 | 12:33 PM
CrankenFine's Avatar
dip?
Old Mar 6, 2013 | 03:18 PM
GTS's Avatar
GTS
Seasoned tech
dip?
He's from the UK. I assume he means low beam. You know when you go low you "dip."
An even better option to vasalene is dielectric grease. It's the actual proper grease for the job, though vasalene will work OK too.
Old Mar 6, 2013 | 04:20 PM
cybercarl's Avatar
You assumed right. it's a bit like us calling chips, crisps LOL
Old Mar 6, 2013 | 11:35 PM
Well... Since vaseline is actually dielectric, it is in fact dielectric grease...
A chevy is a car, but a car doesn't have to be a chevy...
Most brand name dielectrics are silicone based, and last a little longer than vaseline, but in the end, they tend to pick up the same amount of dirt and other stuff making the time between cleanings about the same...
Plus, if you say dielectric grease to someone, half the time you get a Q&A session about it, vaseline just about everyone knows what it is, and most have at home...
Old Sep 25, 2013 | 06:14 AM
Hopey's Avatar
Hopey is on a distinguished road
Good morning,just finnished searching the threads for info on losing my low beam!Had no low beam for about a week now and then lost high beam last night on the way home from work.Put my new bulb in and still no low?Unplugged my eastern beaver relay and put the bulb in the OEM socket and still no low beam! My assumption is the switch it toast,anyone else had this happen?Thanks in advance. Hopey
Old Sep 25, 2013 | 09:57 AM
Start by swapping the fuse, and measure voltage at various points... Switches do fail, but it's unlikely it will fail in both settings unless there is something else wrong...
Old Sep 25, 2013 | 04:21 PM
+1 As always, anything electric you rule!!! and some other things too
inderocker
Apr 26, 2010 06:44 PM
andy9743
Jun 8, 2009 02:04 PM
infidel_mike
Apr 22, 2008 06:32 PM
Randman
Jul 15, 2006 10:35 PM
inderocker
Jun 22, 2005 01:19 AM
