SuperHawk Forum
-   -   sprocket question?? (https://www.superhawkforum.com/forums/technical-discussion-28/sprocket-question-28803/)
Shane702 Jul 17, 2012 10:33 PM
sprocket question??
okay some of you guys said because I got a race chain installed and didn't get new sprockets, they are still stock ones, that is pretty bad... i've been trying to find sprocket information on forum... i've been sitting here for awhile now and I still dont know what the differences are?? can anyone help me out please?? Im trying to order some on ebay.. I hear vortex are pretty good? is that true?? and what is the difference between numbers?? I am new to riding, and ride street.. but I would eventually in the near future like to learn to wheelie(always looked so fun to me) so what would be my best fit?? any help would be much appreciate so I can order them and get my bike up and running and everything the way I want before I start work next week(it is my only transportation, besides taking my girlfriends car), thanks for any info.. or any clarity as I am lost :(
8541Hawk Jul 17, 2012 11:16 PM
1 Attachment(s)
I replied to your PM but will ad some info here.
For your question of what the numbers mean this pic should help
Attachment 14322
The stock chain size on a VTR is 530
Which by looking at the pic means there is 5\8" between the link pins and it is 3\8" between the inside of the side plates.
So people run a 520 chain to save weight but they do wear out quicker and on the street you will not see much advantage.
The one key thing is you must match chain size and sprocket size, which means you must use 530 sprockets with a 530 chain. the same goes for the 520 parts.
I would also recommend running steel sprockets. You will see adds for aluminum rear sprockets. Once again this is more for racing applications and they wear out too quickly for street use.
I would also recommend running the stock gear ratio of 16\41 at first, until you get used to the bike and riding. Then there are a few options you can try but right now I would stay with the stock set up.
saige Jul 17, 2012 11:38 PM
Attachment 14322
+1
16=front sprocket 41=rear sprocket steel sprockets is the only way to go on these beasts,and take your time and learn to ride the bike,dont worry about wheelies,just might end up costing you more money.
Shane702 Jul 17, 2012 11:39 PM
pictures
ImageShack Album - 5 images
hawk these are my concerns
8541Hawk Jul 17, 2012 11:44 PM
Yeah that sprocket is toast..... You do need to replace it.
The header will not cause you problems right now but will need to be addressed at some point. Either replaced or possibly the fill with water and freeze it might work.
Yes those exhausts have been modified but the carb set up thread will give you a set up that will work with them.
Shane702 Jul 17, 2012 11:44 PM
Originally Posted by saige (Post 338035)
+1
thanks saige!! okay how do you think my sprocket looks on rear?? it doesn't have alot of play. just concerned its still the stock sprocket.. and i got a nice expensive chain?? and noo that will be down the line... i just eventually would like to learn how to :).. after this week getting my ss clutch and brake lines / racetech fork springs / gold valve assembly(for the forks forget what they are called) and going to do the pair, carb write up by hawk, and tps write up also... just wanted to know if I should get sprockets while im at it... and i'll be good to go as far as i'm concerned :)... except the exhaust worries me a little, the dent and the fact someone gutted out.. how do you guys think it looks? looks like shit to me lol!!! thanks for the replies guys, appreciated much.
Shane702 Jul 17, 2012 11:47 PM
okay.. i figured man.. they look like shit lol!!! i can't believe these guys said my sprockets are "fine" lol.. im still going to have them install them tho because thats kind of a more major part I dont know if I want to do myself, plus dont have stand... so I will order the 2 #48 jets, STEEL sprockets(hey are vortex good sprockets? i can get decent deals on ebay? little more than your links but any difference??".. and also a oem air filter(since i will be doing the tuning and everyone seems to hate the k&n... and thanks for exhaust, not sure what you mean by the freezing? but when i can afford it i will take care of that... i planned on getting the hid projector kit done by the guy on forums who does the bi-xenon for 350$ total plug and play and sent back... that way im seen at night... god dammit I can't thank you guys enough man!!!
Shane702 Jul 17, 2012 11:50 PM
and hawk.. could that be causing the "pull forward and backward effect" im talking about at low speeds? its a pretty hard pull and back on it.. and higher speeds i dont notice it so much.. guessing cuz im going faster and its spinning faster... o also I ordered the front ape cct like you recommended!! figured why wait till it goes out, have the 2 manuel ape's done, the new f012aa r/r installed.. and do the rest of this junk... to have a good running bike and be as safe as I can at same time!!
Wicky Jul 18, 2012 03:38 AM
Also check your cush drive rubbers and replace if necessary (Part no. 1)
Ronayers.com Microfiche Honda>Motorcycle>1999>VTR1000F>REAR WHEEL
saige Jul 18, 2012 10:47 AM
vortex is good,but not for the hawk,the V-twins eat them up like candy.go with jt sprockets that are steel.you can find good deals on those if you look around.
your old sprockets look ok,but at the same time,they are not,they took shape of the old chain,which is not good for the new one.it will cause the new chain to deform and break down faster.
always buy in complete sets,it wears evenly together which will give it a long life,just keep chain lubed.
which gold valves are you getting for the hawk,what model numbers.
Shane702 Jul 19, 2012 06:30 PM
thanks saige, hawk, and everyone else.. steel sprockets ordered! should be here monday/tuesdayish.. i will take before and after pics as I am doing alot of work to it! i cant find the receipt from shop... i've found every single one besides that one... i know I got racetech forksprings.. and the racetech gold valve assembly that tunes the forksprings... its suppose to be a really good better assembly(the guy who owns this raceshop, is going to be in the AMA race next week.. his name is dale... hes really been an awesome person to me.. and helped me in many ways.. and he has said wow to me many times because of what I let him know I have read here, on the forums... and he is like I can tell you've spent many hours researching this stuff, because most people have no clue... your girlfriend must be getting pissed at you all the time u've spent here and reading online... i was like yep, these superhawk guys have helped me a ton... he wrote the forum down to check it out... i just found out today he qualified and will be 1 of the racers in the ama, on speed channel.. if u guys got time u should check it out!!! :).. he's from racer's edge performance.. thanks again guys!! u've helped me tons!
Shane702 Jul 19, 2012 06:32 PM
thanks wicky.. how would I know if they need replaced? would the shop, doing my sprockets, know if they needed replace dor not?? and I think the shop boy, still learning and loves to ride, is the one who checked my sprockets... so it was a smiple mistake I believe... or he thought they were okay, or whatever the reason... i have no hard feelings towards them... thanks again!
saige Jul 19, 2012 07:12 PM
the more important valve to get is the compression valve.you can get the rebound,but dont get the upgraded one from racetech,i got that one and need to iron out some kinks in it,no one has used that paticular valve,so im working thru the data of it and such.
the best person to contact would be jamiedaughtery,here is the link to his profile.SuperHawk Forum - View Profile: JamieDaugherty
he will sell you new valves for your forks at a better price than racetech.
do you plan on doing any of the work yourself,or just gonna give it to a shop to do.
if i understand,you already ordered the valve,did you get rebound or compression.if you have the model number,just post it up.
Shane702 Jul 19, 2012 07:44 PM
yeah I already have the shop paid in full, they only charged me 300$ labor.. .thats for the following: custom red galfer brake lines, custom red galfer clutch line, psr clutch lever, psr brake lever, front ape manual cct install, front and rear sprockets installed, front flush leds installed, racetech forksprings installed, gold valve adjuster assembly(im going to look for receipt again now, all I know is its for the tunning at the top a whole bunch of little parts I believe he was explaining to me how it works with for springs, it lets you tune better, and all that stuff.. he said it would take around 3-4 hours to get fork springs installed, and the valve kit and getting it tuned correctly... so i'll have to look since Im not sure of difference.
saige Jul 19, 2012 08:19 PM
hmmmmmm,not trying to insult or saying anything bad,but it takes longer to change fork fluid than it does to change the springs,but of course hes doing the valves too,i just hope he knows how to work on these particular forks
there is nothing to add to the forks,except to change out the valves and drill a hole to the gold valve if necessary,if he knows to do that or to look for info on this specific bike.
very important to know which valve.if its the rebound only,not worth much to put in by itself.its the compression thats more important at the moment.the rebound is good enough for now.
the racetech compression gold valve is gonna be either FMGV S2040G which is the G2-R,the newer one,and than the standard compression valve is FMGV S2040
rebound valves are FRGV S02 which is the standard.the newer one is FRGV SR2001
dont get the newer one,its impossible to bleed correctly with out more info on this valve,i have it and need to work out the details.
so just really got to figure out what you are getting,and for the love of god,ask for all the parts that came out of the forks to make sure he did do the job and not just change the oil.
the price of 300 for labor is good,but it is just unheard of for a shop.
to give you idea of what im saying,here is a link to my thread.i need to update it or just make a new one with instructions with what and what not to do.https://www.superhawkforum.com/forum...-issues-28238/
Shane702 Jul 19, 2012 09:01 PM
okay thanks man... well I'm pretty confident in this guy... and his shop... he is going to be one of the racers next week in the ama race on speed television... its my first bike, and he's been helping me alot...i dont believe he has ripped me off.. all the research i've done on these forums, from u guys... have all been exactly what this guy has said... im not sure exactly what it is, but he has a few race bikes with over 100k into them at his shop he has shown me and he did all the work himself and his mechanic... so im hoping they would know what they are doing... and whatever he ordered was out of the 2010 catalog I believe... im pretty sure this guy knows exactly what to do... hes changing the fork springs and the entire assembly below the tuning... i remember him explaining the compression to me and how forks work with the damper and what not... im not sure now... god i found 9 receipts and can't find the one with that part on it... blah... I hope its right..thanks for all the info tho... i hope its not the new one in that case!!! lol
Shane702 Jul 19, 2012 09:07 PM
Dale Kieffer from racer's edge performance in las vegas is the guy who has told me all of this.
saige Jul 19, 2012 09:15 PM
ok,sounds good,if hes been doing all that,than im sure he will get you straight and going good.
have you thought about replacing the steering head bearings while its all apart.
it could wait,its not that hard to do,just time consuming a bit.
HRCA#1 Jul 19, 2012 10:44 PM
Well I've stayed out of this so far but now you're telling us that Dr. Dale Keiffer is working on your bike, sorry I don't think so!
Shane702 Jul 20, 2012 01:39 AM
really? I'm in vegas.. he lives here.. he owns racer's edge performance.. and I'm making this up? lol... alright hrc =]
Shane702 Jul 20, 2012 01:47 AM
and bob his main mechanic is the one who does most the work, but dale does the dyno tuning and is going to do my forks for me.. and while I was there today is how I found out he qualified for AMA next week and will be gone all week from the shop... but calling someone a liar who you know nothing about isn't very friendly... but to the rest of you I really appreciate all the help... and dale is the one who has helped me from day 1.. he is the nicest guy you will ever meet.. he's told me how to flush my radiator, change my oil, what to spend my money on... he's an awesome guy, and im blessed to have the superhawks helping me out, and him not screwing me over.. but by you saying that, just made me smile and made me feel even more blessed than he really is.. =].. now I gotta post a pic up with him and i'll have him hold a sign that says im not dale... and btw... another "secret video" since im a liar... go youtube "gillie suite man head on ground" dale is the one who video tapes him on the track, at about 1:05 in, on a turn, his buddy gillie man(who wears a fully gillie suite when he races) puts his head on the ground on a turn... I guess just anyone would know that... not that dale showed me at the shop or anything :).. and he didn't invite me to my first race next month and is helping me get my bike with my budget ready to go on the beginner course... anyone close to vegas should come check it out.I told him about you hawk and you tweety.. he was curious as how I knew so much so fast and I told him how helpful you guys were and about your write ups and what not... but anyways.. sorry about the rant, but thanks again for all the help.. my bike should be ready by tuesday since he leaves wed for the races.. thanks again you guys who have helped me out!!! you also saige.. much appreciate fellas!
Shane702 Jul 20, 2012 01:51 AM
are those in the forks?? I will ask them tom about that.. are they like the 30$ bearings your talking about?? my psr levels came in, my fork springs valves everything is ready... but I had him order my sprockets today, and im waiting on my front ape cct also.. so either monday or tuesday I will get it all taken care of... I will be sure to drive down tom since its only a 10 minute drive and ask them about that... one of his guys is getting his bike registered after 7 months and is going to start teaching me how to wheelie this weekend.. im kind of worried tho, dont wont to wreck my bike already :(.. but i'll take the advice from these guys.. anyone recommend any frame sliders that are good quality that I can get?? i'd really like to protect my bike... blah...
Shane702 Jul 20, 2012 01:57 AM
this is me being a liar.. =] a lil after 1 minute in fellas ^^ happy watching
about 1 minute in I drag my helmet on the race track in a 10% banked corner in 3rd gear on my Predator gsxr 600. Dale from Racers Edge is filming and we were just playin on the track. Please do not try this and thanks to the race track for not kicking me out. "hint" they will normally kick u out-insanod
E.Marquez Jul 20, 2012 05:05 AM
Ghilli man Draggin his helmet going fast - YouTube
Best of luck on your bike, with whoever is working on it for you.
Not sure what a YouTube video does for your statements above, proves anyone specific is working on your bike, or is anything more then a You Tube video on a pubic accessible network... But it's a good vid, so there is that.
saige Jul 20, 2012 06:45 AM
no,its in the neck of the bike for the top and lower triples.
the stock ones are ball bearing,the best ones to get is the allballs bearings,which are needle bearings.
bike will track so much better with them,if done ane torqued properly.
Shane702 Jul 20, 2012 08:06 AM
Alright thanks man..I'm going to ask here in a little bit...thanks for the tips staig I'm sure will be a good investment since its such a small cost to what I have done
Shane702 Jul 20, 2012 08:09 AM
Just really hate being called a liar, when I didn't even know it was that big of a deal you know? Just the fact it only says "dale" not his last name was just trying to state it's a video going nuts and no one would know really but he showed me himself so I thought it was pretty cool.thats all I guess..whatever :).appreciative of the info, that's all :D
E.Marquez Jul 20, 2012 08:10 AM
The tapered steering head bearings are one of those things folks ignore.. until what they have is really bad... and then once new bearings are installed, they don’t understand why they waited so long.
saige Jul 20, 2012 08:42 AM
lol +1000 on that,i had my head bearings for the longest time,trying to wait to do as much as i can in one shot,I wished i wouldve taken care of that first.it wouldve made my rides so smoother when i had good tires.
even with bad,mismatch tires,i can track it a lot better.
its something like 30 or so bucks for the fix,its well worth it, especially if you upgrading fork internals.
Shane702 Jul 20, 2012 09:03 AM
Awesome..and I don't think my hawk was ever maintained so I'm sure this would be well worth my time at such little money...does it cost them to much more time to throw them in?
