Spark plug problem
Old Jul 27, 2013 | 10:43 PM
That One Guy's Avatar
That One Guy is on a distinguished road
Spark plug problem
Pulled the throttle too much on the old bird and the front spark plug blasted out of the threads to god knows where. Threads are now stripped. I was wondering if anyone knew of a way to fix this (besides the obvious head replacement or helicoil that involves removal and drilling). I was informed that there was something similar to a helicoil I could buy, that does not require drilling. just a tap kit and you crimp, press and turn this tool into the housing. Then release and it expands, working with the minimal thread left, but expanding so it won’t come out. Any help/suggestions would be fantastic. I’m dying without my bike.
Old Jul 28, 2013 | 06:11 AM
Never seen such a thread repair insert.
Perhaps ask the person that "informed" you about that type of thread repair kit.
I use TimeSert spark plug repair kit, when the need arises.
The TimeSert uses a cutter, tap and install tool.. no drill bit
4212-note
But bottom line, your still making chips.. ..
My opinion, there is no way to do the task correctly that does not involve removing the head.
That in itself is not overly involved for a experienced home wrench.
Old Jul 28, 2013 | 07:48 AM
Well... If the plug shot out, I'd investigate other issues than just threads... Going WOT has never ever shot a spark plug out on it's own, unless someone threaded it in there incorrectly damaging threads...
More likely you have blown the entire top end with a failed CCT...
Old Jul 28, 2013 | 10:59 AM
CCT is fine. I pushed a new spark plug in and held with a special little rig of my own for the sake of start up. Runs fine. Possibility would be that the plug was not torqued properly when I had the motor built (moriwaki pistons, high compression rods and valve job). I’ll check out your way, Marquez, and see what I can do. I have already cleaned the housing out from any shavings. should be simple from here out. Tap with catch thread just a little, but the plug can push straight down with a little force.
Old Jul 28, 2013 | 12:19 PM
Is it the correct plug?
Old Jul 28, 2013 | 03:23 PM
Yes. I’m not mechanically retarded. I am very handy with a wrench around a garage.
Old Jul 28, 2013 | 03:27 PM
I even tried sticking the old plug from the back cylinder in it. No dice on catching thread. Guess I’m going to have to install the timesert.
Old Jul 28, 2013 | 03:41 PM
No offense, but you said you had the motor built. Thought maybe you had it built by someone who was mechanically retarded.
Old Jul 29, 2013 | 03:32 PM
That’s a good possibility. It has been running fantastic until that little mishap. halfway considering parting it out or selling it right now.
Old Jul 29, 2013 | 03:41 PM
4212-note
Do you recommend the standard or deep hole for the front cylinder?
Old Jul 29, 2013 | 04:51 PM
Long.. the top of the sparkplug thread is 4.75" from the head top... you will need the long reach tool to get full thread engagement.
Old Jul 29, 2013 | 10:45 PM
sailorjerry's Avatar
Dibs on the motor
Old Jul 30, 2013 | 02:50 PM
Originally Posted by sailorjerry
Dibs on the motor
If that happens, I’ll message you. I’m trying to make some money soon on it. If anyone wants to take bike, I’ll sell it for 3k. moriwaki pistons installed with new cct. 10.0/1 compression as opposed to factory 9.4/1. makes me very happy when I goof off on the track and the power band is so much more open (tweety knows what I mean). Electric blue paint with zg screen, extended passenger pegs with integrated led blinkers drilled into the pegs. very cool looking. I have an extra back tire and extra parts laying around that will go with it.
Old Jul 30, 2013 | 06:05 PM
I know they make a whole kit to rebore spark plugs on ford pickups, since they have an inherent problem with plugs melding to the heads. Its really amazing, it goes in, rebores a thread and threads in a hardened sleeve for the plug to thread into.
Not sure if it can be used on hondas. It was on the show truck u.
Old Jul 30, 2013 | 06:08 PM
Honestly though I would call a local machine shop, see if they can do a repair to the head, and just do the work yourself if you can. It's not that hard of work to get the head off and most machine shops are fairly cheap for repairs like that.
Old Jul 30, 2013 | 06:18 PM
A: Triton uses a different size plug.
B: the Triton spark plug rethreader kit is nothing special, and much like the one I posted from time cert
Old Jul 30, 2013 | 07:41 PM
Ok so yeah, do what Eric said, DONT give up on the whole bike because of one plug. That happened to my cbr at like 22k miles and I rode it to around 98k miles inlcluding racetrack miles. I guess I just forgot I repaired it.
Old Aug 10, 2013 | 07:00 PM
I’m just too poor to buy stuff…..
Old Aug 10, 2013 | 07:01 PM
if someone would buy my extra left side rear set with shift shaft and the oem turns, I would have enough to buy the timesert.
Old Aug 10, 2013 | 09:43 PM
saige's Avatar
the boss
how much is the kit.
if its more than the heads on ebay,than i would just buy this one and order a gasket and youre good to go.
00 Honda VTR 1000F Superhawk Head Cylinder Base Valves Front 98 99 00 01 | eBay
Old Aug 10, 2013 | 10:00 PM
It’s less for the timesert. 65 or 70
Old Aug 11, 2013 | 06:33 AM
TIME-SERT 12MM X 1.25 Spark Plug Repair Kit 4212E
Try double that... More like $180 or so
TIME-SERT Metric Spark Plug Kit M12x1.25 Extended Spark Plug Kit Part # 4212E : Amazon.com : Automotive TIME-SERT Metric Spark Plug Kit M12x1.25 Extended Spark Plug Kit Part # 4212E : Amazon.com : Automotive
http://www.mechanicstoolsandbits.com...it-p-5527.html
http://www.ebay.com/itm/TIME-SERT-Me...-/270801057783
http://www.ebay.com/sch/TIME-SERT%20...0Kit%20Part%20
EDIT: Or did you mean $65-70 to have it done by a shop??? If so that makes sense...and what I would expect in cost...
Old Aug 11, 2013 | 07:38 AM
I know that eBay listing say FRONT, but that's a REAR head.
Old Aug 11, 2013 | 07:01 PM
saige's Avatar
the boss
after looking at the photo for a second,youre right.
Old Sep 16, 2014 | 04:46 PM
rz_racer_69's Avatar
Old and dangerous
Does anyone have the kit they can loan me? I know I have to buy the inserts but seems like a waste to buy the kit for one cylinder head.
That One Guy
Jun 29, 2013 12:04 AM
seattlesucks
Jul 26, 2007 06:48 PM
ATLSHawk98
Dec 21, 2006 09:32 AM
motojoe
Oct 3, 2005 04:19 PM
Quebecer
Jun 29, 2005 08:18 PM
