Spark plug problem
Pulled the throttle too much on the old bird and the front spark plug blasted out of the threads to god knows where. Threads are now stripped. I was wondering if anyone knew of a way to fix this (besides the obvious head replacement or helicoil that involves removal and drilling). I was informed that there was something similar to a helicoil I could buy, that does not require drilling. just a tap kit and you crimp, press and turn this tool into the housing. Then release and it expands, working with the minimal thread left, but expanding so it won’t come out. Any help/suggestions would be fantastic. I’m dying without my bike.
Originally Posted by That One Guy
(Post 359708)
Perhaps ask the person that "informed" you about that type of thread repair kit. I use TimeSert spark plug repair kit, when the need arises. The TimeSert uses a cutter, tap and install tool.. no drill bit 4212-note But bottom line, your still making chips.. .. My opinion, there is no way to do the task correctly that does not involve removing the head. That in itself is not overly involved for a experienced home wrench. |
(Post 359708)
More likely you have blown the entire top end with a failed CCT... |
CCT is fine. I pushed a new spark plug in and held with a special little rig of my own for the sake of start up. Runs fine. Possibility would be that the plug was not torqued properly when I had the motor built (moriwaki pistons, high compression rods and valve job). I’ll check out your way, Marquez, and see what I can do. I have already cleaned the housing out from any shavings. should be simple from here out. Tap with catch thread just a little, but the plug can push straight down with a little force.
Is it the correct plug?
Yes. I’m not mechanically retarded. I am very handy with a wrench around a garage.
I even tried sticking the old plug from the back cylinder in it. No dice on catching thread. Guess I’m going to have to install the timesert.
No offense, but you said you had the motor built. Thought maybe you had it built by someone who was mechanically retarded.
That’s a good possibility. It has been running fantastic until that little mishap. halfway considering parting it out or selling it right now.
(Post 359725)
Never seen such a thread repair insert.
Perhaps ask the person that "informed" you about that type of thread repair kit. I use TimeSert spark plug repair kit, when the need arises. The TimeSert uses a cutter, tap and install tool.. no drill bit 4212-note Do you recommend the standard or deep hole for the front cylinder? |
Long.. the top of the sparkplug thread is 4.75" from the head top... you will need the long reach tool to get full thread engagement.
(Post 359820)
Dibs on the motor :evillaugh: |
Originally Posted by sailorjerry
(Post 359845)
I know they make a whole kit to rebore spark plugs on ford pickups, since they have an inherent problem with plugs melding to the heads. Its really amazing, it goes in, rebores a thread and threads in a hardened sleeve for the plug to thread into.
Not sure if it can be used on hondas. It was on the show truck u. |
Honestly though I would call a local machine shop, see if they can do a repair to the head, and just do the work yourself if you can. It's not that hard of work to get the head off and most machine shops are fairly cheap for repairs like that.
(Post 359918)
Not sure if it can be used on hondas. It was on the show truck u. B: the Triton spark plug rethreader kit is nothing special, and much like the one I posted from time cert http://cdn2.bigcommerce.com/server49...12.220.220.jpg |
Ok so yeah, do what Eric said, DONT give up on the whole bike because of one plug. That happened to my cbr at like 22k miles and I rode it to around 98k miles inlcluding racetrack miles. I guess I just forgot I repaired it.
I’m just too poor to buy stuff…..
if someone would buy my extra left side rear set with shift shaft and the oem turns, I would have enough to buy the timesert.
how much is the kit.
if its more than the heads on ebay,than i would just buy this one and order a gasket and youre good to go. 00 Honda VTR 1000F Superhawk Head Cylinder Base Valves Front 98 99 00 01 | eBay |
It’s less for the timesert. 65 or 70
(Post 360709)
Try double that... More like $180 or so :(
TIME-SERT Metric Spark Plug Kit M12x1.25 Extended Spark Plug Kit Part # 4212E : Amazon.com : Automotive
http://www.mechanicstoolsandbits.com...it-p-5527.html http://www.ebay.com/itm/TIME-SERT-Me...-/270801057783 http://www.ebay.com/sch/TIME-SERT%20...0Kit%20Part%20 EDIT: Or did you mean $65-70 to have it done by a shop??? If so that makes sense...and what I would expect in cost... |
Originally Posted by saige
(Post 360707)
Originally Posted by VTR1000F
(Post 360725)
I know that eBay listing say FRONT, but that's a REAR head.
after looking at the photo for a second,youre right. |
Does anyone have the kit they can loan me? I know I have to buy the inserts but seems like a waste to buy the kit for one cylinder head. :(
