sometimes back fires on starting
Old Apr 8, 2009 | 09:36 PM
MLB's Avatar
MLB
MLB is on a distinguished road
usually fires as soon as it's cranked, but sometimes it won't and will crank for a few seconds after which it will back fire and then immediately start.
I drilled out the the endcap of the stock exhaust last fall. No airbox/filer changes.
Old Apr 8, 2009 | 10:02 PM
shayne's Avatar
What are your jetting specs?
Old Apr 9, 2009 | 04:53 AM
gboezio's Avatar
Flodded, make sure that the petcock cuts the fuel flow when the engine is off. Gas smell ??
Fouled plugs, check them.
Misadjusted choke, try using less.
Old Apr 9, 2009 | 08:20 AM
nath981's Avatar
did you check the TPS? that's probably the first thing I would check since they are notorious for being out of adjustmt. I had to adjust mine after years of varying degrees of popping/backfiring that eventually increased to unacceptable levels. What a difference.
Old Apr 9, 2009 | 11:32 AM
MLB's Avatar
MLB
Stock jetting. I'm not much of a wrench so what's to "check" on the TPS (throttle position sensor?)
No gas smell.
Another "problem", choke is too "tight". When I pull it all the way out, if I let go it pulls back in enough that the bike will stall if cold. Pull it out and hold (what I normally do) and it idles 500 rpm faster (normal cold start rpm)
I assume it needs adjusted somewhere, but where?
Thanks!!
Old Apr 9, 2009 | 12:00 PM
That's an easy fix. If you pull back the rubber boot directly past the choke **** you will find a plastic nut that adjusts the resistance that holds the choke out. (you don't weaken the spring, but rather increase the friction that holds the choke out)
Old Apr 9, 2009 | 12:53 PM
RickB's Avatar
Mine does this once in a while, I always attributed it to being slightly lean when starting it cold.
Old Apr 9, 2009 | 12:58 PM
nath981's Avatar
No gas smell.
Thanks!!
the TPS is a plastic sensor on the side of the rear carb. it needs to be checked with a multimeter. It is secured with rivets that need to be surgically removed to avoid buying a new one. it's a bit easier if you pull the carbs up and tilt them. There are many references and pics on this forum if you need more info to decide if you want to tackle it. It helps if you have a dremel(cutting disc) to cut slots on the rivets so they can be removed. If you have a buddy that is handy, it might be best to seek help.
Old Apr 10, 2009 | 01:10 AM
shayne's Avatar
It is possible that your bike is lean. Backfiring is a sympton of this. A dyno tune may fix the problem.
Old Apr 10, 2009 | 09:46 PM
MLB's Avatar
MLB
Thanks guys! I'll fix that choke this weekend.
I've been suspecting lean too, just really surprised that drilling some holes in the end cap with no airbox or filter changes would make that much difference. it does growl nicely though.
Old Apr 10, 2009 | 10:22 PM
nath981's Avatar
I don't believe it would. I did that exact thing first and ran it quite a while without any problem. get someone to check your TPS if you don't feel confident enough to do it yourself.
Old Apr 11, 2009 | 12:50 AM
fighter hawk's Avatar
chopped and screwed
fighter hawk is on a distinguished road
mine backfires under deceleration like no other. its a build up of fuel in my case. if either of your coils aren't throwing spark fast enough may cause this as well. you have more fuel than spark track it down it may just take a lot of trial and error
Old Apr 12, 2009 | 01:13 AM
Fozzy Bear's Avatar
Fozzy Bear is on a distinguished road
Is this when starting from cold or hot? Do you twist the throttle much when starting?
I don't think there's anything wrong with your bike, its your starting technique.
Old Apr 12, 2009 | 11:09 AM
MLB's Avatar
MLB
Ok.
Cold only. and not all the time, just a few times. But all since I drilled the endcaps.
Full choke, don't touch the throttle. Just like every other of the 15 odd Honda's I"ve owned over the past 40 years.
Old Apr 13, 2009 | 05:36 PM
Fozzy Bear's Avatar
Ok.
Good to hear. When I removed the baffles in my stock cans, about the only difference was that she idled a bit higher. Starting was just the same.
8541Hawk
Oct 5, 2010 08:39 PM
RoofCleanPhenom
Apr 15, 2008 09:49 AM
Firehawk_ordie
Oct 24, 2007 04:56 AM
MarineHawk
Jun 24, 2007 09:50 AM
MikeD
Mar 8, 2005 10:34 AM
