Signals take forever to work in morning.... partial fix!
Old May 2, 2009 | 06:14 PM
CentralCoaster's Avatar
Sometime around when I replaced the r/r and front signals, the signals started acting up, and took about 30-60 seconds to start working on cold mornings. After that, they work normally.
They worked fine when the bike was not running, go figure.
I put some dielectric bulb grease on the wire connections to the blinker module (inside right rear plastic), and on the wires feeding all four signals, and on the front bulbs. I couldn't get the rear bulbs out.
My blinkers now only take about 5 seconds to start on cold mornings.
My guess is the aftermarket bulbs have different types of metals on the connectors and at the bulb. Humidity in the air causes a small amount of surface corrosion to build up between the metals. The grease prevents this.
Old May 2, 2009 | 09:33 PM
chickenstrip's Avatar
chickenstrip
Good to know. I've been dealing with the same problem (there's at least one other thread regarding it) and cleaning the bulbs and sockets is my next step. I want to get rid of all delay.
Old May 2, 2009 | 10:25 PM
Circuit_Burner's Avatar
guru of things sparky
When R/R fails it sometimes heats up a bunch of stuff like bulb sockets and multi prong connectors all over the bike. A new winker relay didnt fix one of mine, and I took all the plugs apart and cleaned them with 'De-Oxit". Behold, it wasnt one of the many plugs, it was the left handle-switch assy.
Dis-assembled and De-Oxit'ed everything, and it worked like new.
If you havent cleaned and inspected the left handle-switch, thats where your remaining 5 seconds is hiding.
Old May 2, 2009 | 10:47 PM
chickenstrip
Yeah, I did that one. I've still got a 10 sec delay. My bike's apart at the moment, but I'll get to the bulbs once the other stuff is back together.
deltaboxii
Apr 13, 2013 04:28 PM
rz_racer_69
Sep 18, 2012 03:29 PM
RK1
Jul 6, 2010 07:36 AM
torquepeak
Jun 19, 2007 08:33 AM
Zedicus
Mar 19, 2007 06:10 PM
