Rubber Seal on tank cap
Old Feb 12, 2008 | 04:41 AM
Gerrit's Avatar
Gerrit is an unknown quantity at this point
Hi Guys!
It seems that my tank loses fuel thru the overflow pipe, as fuel escapes past the rubber that is supposed to seal on the tank opening.
Whether the tank is full or half, it seems that any fuel "sloshing" around, and hitting the cap, gets past the rubber seal and flows away via the overflow pipe.
Anyone know of a quick fix, or a replacement rubber for the cap?
Regards,
Gerrit
Old Feb 12, 2008 | 09:05 AM
andy9743's Avatar
Gerritdlr: where does it run down after the overflow? i have stains on the right side of the frame right at the bottom right of the tank (from gas leaking out somewhere and picking up the rattle can black that the po sprayed all over the bike including the underside of the tank)
thanks!
my rubber on top is all dry rotted also...possibly my problem too!
Old Feb 12, 2008 | 10:20 AM
Gerrit's Avatar
Hi Andy, with the tank cap open, you will notice a hole in the recess in the tank (On the left of the cap).This hole is the start of a pipe that runs somewhere inside the tank, towards the petcock at the back of the tank...at that point this pipe has a "nipple" that has a rubber tube attached, and this tube runs down, to dispose of overflow fuel.
I have had many hours withthe tank, as the bike would die after ridinga few minutes, due to pressure build-up, as the "breather pipe" was blocked. The breather also has a "nipple" next to the petcock with a rubber tube attached that runs downwards.
Hope this helps, Gerrit
Old Feb 12, 2008 | 10:40 AM
Gerrit's Avatar
Nope no luck, just did the switch, still no headlights
SIRR1
Apr 30, 2015 08:44 PM
maniac2313
Jun 28, 2011 04:53 AM
tbartley
Jul 20, 2009 08:26 AM
Timmybung
Apr 28, 2008 10:47 AM
flngscout
Nov 20, 2007 01:53 PM
