Riddle me this: Intake valves way out of spec
Yeah gotta support the home team Maricopa County, Arizona; the only county in the U.S. who is defending us from the dangers of motorcycle pollution!
I'll check often. It's not hard to pop a valve cover off, and I'm almost certain that just shimming won't actually "fix" the problem, just the symptoms. If I pull a head again, though, I'm going to want to upgrade something, and I'll need some expendable cash that I don't have budgeted at the moment.
It's pretty much guranteed it's just the valve faces wearing for what ever reason. I can gurantee it's not a cam. If it was something galling you'd hear it and it'd lock the cams up and you'd have a lot more damage and runability problems.
Yes shimming is a bandaid but it gets you back on the road for now. If it continues to wear and need adjustments then you'll know you'll need to be pulling the head and replace the valves. And it gives you time to prepare yourself for the cost, labor of doing the job.
I'd give your mechanic a call right away to let him know and see what the likelyhood of him warranting it is.
While some can guarantee that specific parts can no way be damaged without seeing them, I find that hard to do but I guess I'm just old school.
When asked what possible could cause the problem, I'll give you a list of things that could cause what you have experienced.
To eliminate components, without checking them for no other reason then to rule it out as part of the diagnostic process is poor troubleshooting.
So yeah it is probably the valves recessing into the head but as this is not the only possibility, I would check all the possible causes before checking things that require engine dis-assembly.
Carry on and argue among yourselves if you feel the need.
If there's one thing this bike has demonstrated to me, it's to not rule out anything until I've checked it at least twice... It started it's life as a craigslist gem and I look forward to idly checking cam specs only to find out I've got ones meant for the Varadero for some weird reason, lol!
Checked cams, they were right in spec. Bolted it together, compression is right back up in the 150 range. She purrsssss.
So it was the valves all along. Now to throw some 45 pilots in and run to emissions. Then I'll have to figure out what to do about these wearing valves. It's not over but it's good to know at least the general vicinity of what's wrong.
Moral of the story is to check compression way sooner in the diagnosis.
Very strange. I cant quite picture how it got so badly F'd that the valves would sink themselves into the seats that fast, unless they were reground through the hardfacing.
I have a set of stock '00 VTR cams that I took out of my engine when I built it. They have ~5k total miles on them. They've been stored in a Moriwaki cam box on the shelf since 2003.
Exactly. With the exception of two things: 1) I now know generally what is happening. Not why yet, but what. 2) I can get the bike emission tested which is due this month and not have to deal with more DMV crap than necessary with registration. At least while it's running. I'll pull the covers in a month or so and re-asses my plan of action.
Glad to hear you got it running well again. At least for now. Though you know you still have some work ahead of you in getting the problem actually fixed. But you've given yourself some time to get it fixed.
It's not poor troubleshooting, it's about listening to the symptoms and having the experience and knowledge of how all the components work to make an accurate diognosis.
3amta3
Oct 1, 2011 06:48 AM
Death Cattle
Aug 12, 2008 10:02 PM
F1 Fan in Nascar Land
Jan 26, 2007 12:25 PM
zimm
Sep 27, 2006 12:02 AM
