Removing the engine.
Old May 9, 2010 | 07:10 PM
heng47's Avatar
heng47 is on a distinguished road
Hi guys, already spent a couple hours running several searches here but this question wasn't answered.
I'm a final year student in an industrial design course and just bought a VTR so I could use the engine in my build. Sometime this week (or next), I'm planning to remove the engine to get measurements for building a frame jig. Once that's done the engine goes back into the frame again temporarily (because I want to ride it) until August or later when the chassis building starts.
The last engine I've ever removed was my NSR250 almost 8 years ago so I'm rather rusty at this.
Any advice?
The search turned up something about a unique nut/bolt remover. Anyone have pics?
Old May 9, 2010 | 07:13 PM
The service Manual should have all you need:
https://www.superhawkforum.com/forum...ad.php?t=11365
Old May 9, 2010 | 10:19 PM
Do you have a motorcycle lift of somthing to secure the front end?
Old May 10, 2010 | 03:52 AM
heng47's Avatar
A working link! Thanks! Threads I saw all linked to a lost thread on the bikechatforums.
heng47's Avatar
Nope. Will be building everything from ground up, stands, jigs, etc.
Old May 10, 2010 | 06:56 AM
cliby's Avatar
you'll need some special wrenches or modified sockets (search) to remove the engine mounting bolts. Having a hoist or rafters you can tie to, as mentioned to secure the frame is needed.
Old May 10, 2010 | 11:06 AM
killer5280's Avatar
All I can say is I hope you're not building a chopper or some other godawful bastardized thing out of the Super Hawk.
Old May 10, 2010 | 12:16 PM
FL02SupaHawk996's Avatar
Fastest Color
http://fiche.ronayers.com/Index.cfm/...71/Group/FRAME
I can't find the castle head nut sockets on Ron Ayers, but if you look at the frame in the above link it looks like there's 3; 1 @ 22mm & 2 @ 20mm, so you could get that sized sockets and grind them down to fit...
Old May 10, 2010 | 12:30 PM
Fastest Color
http://www.ablett.jp/bikes/vtr/red_vtr.htm
found this too
Old May 10, 2010 | 01:02 PM
Fastest Color
http://cgi.ebay.com/ebaymotors/Slott...motiveQ5fTools
This approach might work too...
Old May 10, 2010 | 02:07 PM
heng47's Avatar
Perfect! Going to try just that! Thanks!
Old May 10, 2010 | 02:09 PM
heng47's Avatar
Actually I'm building a UJM with variable geometry ala RSV4 chassis. The idea is simple, 1 'base' machine that is easily modifiable between racer, tourer and fighter without the need to cut and weld. Of course, a UJM actually requires an il4, but the Vtwin just has more engine character, and this is justifiable because motorcycles are more of an emotional purchase compared to other typical industrial products like say, a toaster.
Old May 10, 2010 | 04:11 PM
shayne's Avatar
My method for disassembly was to make an engine stand that fitted the engine at its height off the ground while still in the frame. I then bolted it on, and removed all the other bits from the engine, leaving it behind.
No need for suspending the frame when doing this.
Old May 10, 2010 | 10:02 PM
heng47's Avatar
shayne, would you happen to have any pics of that stand?
Old May 10, 2010 | 11:17 PM
killer5280's Avatar
Excellent. A UJM is perfect and the Super Hawk engine really suits it.
I don't think I could stand to see yet another variation on the "cruiser" or chopper theme. Been done a zillion times. They are cliches.
Old May 11, 2010 | 12:02 AM
shayne's Avatar
No pics, which is just as well!!! Too rough!!!
All I did was put the bike on a rear stand, and then put blocks under the sump. I then used some steel I had lying about to make up a stay between the front cylinder head and the ground. This stopped it rolling forward or side to side when the front and rear suspension was removed.
When it came time for re-assembly I just put the motor back on the blocks and the support stay, and then bolted the frame and suspension back onto it.
It was that simple.
Old May 11, 2010 | 06:04 AM
Fastest Color
http://cgi.ebay.co.uk/ws/eBayISAPI.d...K%3AMEWAX%3AIT
I think this one might fit the 22mm castle...from what I can find it's around 21mm.
Old May 11, 2010 | 08:20 AM
Fastest Color
This may be the best solution for both castle head frame bolt locking nuts:
http://www.craftsman.com/shc/s/p_101...2_00934299000P
Sears has a set for <$30 that will fit both with little to no modifications...
Old May 11, 2010 | 09:36 AM
RCVTR's Avatar
A Honda dealership can order them for you. then you can spend your time making your bike run, rather than trying to kluge some kind of tool from a bunch of crap you have lying around.
Maybe it's just me...
Old May 11, 2010 | 09:40 AM
Fastest Color
LOL! I agree, but I called the stealer just now and they didn't get a hit on the part numbers
Old Jun 15, 2010 | 02:29 PM
heng47's Avatar
Managed to contact this guy, he already sold his VTR so he's giving me the tool. I'm finally going to take the engine off now, reading the manual it says I have to drain the cooling system.
As long as it isn't disgusting or dirty, can I re-use the coolant?
I suspect the coolant inside should be new so dumping it seems like a waste.
Old Jun 15, 2010 | 07:16 PM
I would change it unless you had recently done so.
Old Jun 15, 2010 | 07:43 PM
residentg's Avatar
see post #24 of this thread for an another option:
https://www.superhawkforum.com/forum...ad.php?t=22476
Old Jun 25, 2010 | 02:57 AM
heng47's Avatar
I went through the manual several times and devised my own steps to strip the engine. First of all, I'm leaving the exhaust intact because it's too much of a bother getting new gaskets and all that, and also because I don't have the asterisk driver for the pipe band bolt. It's very badly rusted and will not be easy to remove.
Next, I unplugged the wire harness from everything I could see and removed the sub frame. I've untied all the cable ties so the harness will come off together with the frame but the other wires/cables/tubes will not.
I took out the air box and drained the radiators, I didn't measure but it looks like around 2 litres of coolant came out. I didn't want to drain the oil so the oil cooler is still connected but unbolted from the mount.
Some questions.
Are these parts a part of the air box?
I'm trying to find out how the air is routed but there doesn't seem to be any kind of ducting in there.
I suppose I need a new gasket here?
This is the mid mounting bolt, I already removed all 3 castle nuts and also removed the 2 bolts in the middle from both sides. I'm not sure how to remove this, do I need to? I'm assuming it's mounted because it's threaded though on the outside. I don't have a large enough allen key either so I couldn't find out. The manual didn't go into specifics so I'm just guessing. I can't remove the other 2 bolts, I need someone to help me hold the other side otherwise it just spins on the spot.
Old Jun 25, 2010 | 03:05 AM
The idea behind that plastic shield is to make an airpocket that isn't directly in the wind, and have the airbox draw from that... Makes for less actual power, but a lot easier dynamics and tuning...
Yes, a new gasket is needed...
And yes, you need a large allen key...
Old Jun 25, 2010 | 04:34 AM
residentg's Avatar
You can make large allen sockets by welding a bolt with the proper sized head (12mm or 14mm, whatever...) into a socket. The shaft of the bolt goes into the opening of the socket - a cheap one with the proper sized opening will do. Does this make sense? JB
Old Jun 25, 2010 | 05:22 AM
tbartley's Avatar
Makes perfect sense to me. That's how I made mine for my old Kaw Connie when I wanted to remove the front axle. Better to fabricate than spending a fortune on a "specialty" item/tool .
Keep us posted on your progress, Heng47! You're putting something on a thread that someone will definitely be able to use at a later time.
Old Jun 25, 2010 | 05:23 AM
bjorn toulouse's Avatar
Destructive Tester
Only if there is no Sears or NAPA store nearby that sells a 12mm allen socket.
Just sayin'.
Rex
Old Jun 25, 2010 | 06:08 AM
residentg's Avatar
Just sayin'.
Rex
The last one that I made was 22mm for a set of Xr200 forks. Not a common item, and if they did have it, would be very expensive. I used it twice, once for each fork.
Old Jun 25, 2010 | 06:24 AM
Destructive Tester
OK, but that won't fit the bolt heng47 has to mess with....he needs a 12mm.
Rex
