regulator rectifier temp
Old Oct 29, 2007 | 06:51 AM
ali_squidz's Avatar
I replaced the regulator rectifier on my bike with the new finned one. I let the bike idle in the garage yesterday to make sure everything was ok. The RR got really hot. How hot do they run if they are fine?
Old Oct 29, 2007 | 06:57 AM
redman's Avatar
hot...hence the fins....
Old Oct 29, 2007 | 06:58 AM
There is a reason they are finned these days. It will depend on the power draw etc.. And it is backwards.. The more electricity used the less heat the R/R will make. Because the way the R/R works is it turns excess unused power generated by the stator into heat. (so high beams on headlight will have the R/R create less heat etc.)
Old Oct 29, 2007 | 07:04 AM
ali_squidz's Avatar
ok thanks guys!
my old one had cracks in the plastic part and it looks like the crap inside it puked out.
Old Oct 29, 2007 | 12:25 PM
I drilled many small holes on the undeside of the side panel (are invisible unless you bend down to look) to enhance the cooling. That was over 50,000 km ago (when I installed the new vented unit) and all is well....
Montana
Oct 9, 2012 05:40 PM
chickenstrip
May 30, 2007 11:48 AM
wardo996
Apr 26, 2007 08:43 AM
Blurr
Sep 14, 2006 08:58 PM
CNI Dawg
May 31, 2006 05:55 PM
