Rear wheel bearings
Old May 23, 2009 | 08:54 AM
fuzzuki's Avatar
fuzzuki is on a distinguished road
Rear wheel bearings
Mine are shot with only 60,000km.
Do other people have this issue?
Any tips on getting the old one's out?
Old May 23, 2009 | 11:57 AM
Circuit_Burner's Avatar
guru of things sparky
Only ? lol
Damn
That to a bike is like going around the world 11 times.
They probably already have been changed twice.
Getting them out is easy, if your wheel has a snap ring, make sure the snap-rings are out, my wheels have no bearing rings or clips.some rear wheels do.
Use a hammer and a chisel if you dont have bearing drivers of the right size.
Putting the new ones in is where you can screw up.
Dont drive the inner race, only drive the bearings in by their outer races.
Bearing driver or big socket needs to fit decently on outer race.
People beat them in with crescent wrenches and they still work, but do it right and
the bearing will live long and prosper.
Old May 23, 2009 | 11:59 AM
fuzzuki's Avatar
I already have them out. It was pretty easy.
Looking for something good to press new ones back in.
I'm looking for the right size PVC pipe.
Old May 23, 2009 | 12:09 PM
cliby's Avatar
I doubt PVC pipe will be strong enough - they are a tight fit. If you can put them in the freezer for a couple hours first and better still if you have a small torch heat up the hub. Use a socket the correct size - the socket side not the flat side - easy to cut/damage the plastic seal on the bearing or hit the actual bearings or inner race - ruining or significantly shortening its life. Did you check the one on the cush drive?
Old May 23, 2009 | 12:27 PM
fuzzuki's Avatar
The one in the cush drive is fine.
Only the disc side bearing is toast, but I'm replacing both.
If the cush drive goes, it's easy to replace.
I've used PVC to push bearing in before.
It depends on the thickness of the pipe.
Old May 23, 2009 | 12:31 PM
60,000 KM is only 30,000 miles or once around the world.
That is a little early I think. Perhaps once when the wheel was put on they were pinched wrong?
Old May 23, 2009 | 04:51 PM
fuzzuki's Avatar
I think I know why the bearing went early.
I love to change left turning power slides into a transition wheelie.
I'm sure the right side bearing is pretty stressed during this move.
But I don't care, I love doing it.
Old May 23, 2009 | 06:00 PM
Use the old bearing to tap the new bearing in. Tap only on the outer race in a rotating pattern.
Old May 23, 2009 | 06:16 PM
+1
I don't know if the bearings are recessed in the hub, but if they are, and if you have access to a grinding wheel, grind a little off the outside edge of the old bearing to prevent getting it stuck in the hub.
This works for dual tapered wheel bearing outer races on cars and trucks as well.
And use a brass drift to drive out the old bearing. That will prevent damaging the hub.
Old May 23, 2009 | 06:18 PM
Where did these pop-ups come from?
We're getting spammed on key words.
Old May 23, 2009 | 07:48 PM
fuzzuki's Avatar
The one disk side bearing is recessed.
I found an old bearing race that I had in my tool box.
It will make a perfect drift. It's already a few thou. smaller.
mikstr
Jul 20, 2012 05:45 PM
executioner
Apr 27, 2012 03:54 AM
vtrwillie72
Aug 11, 2010 07:37 PM
newb007
Dec 24, 2008 01:16 PM
TommyboyinMI
Apr 15, 2007 06:16 PM
