Really Rich...
Old Oct 26, 2012 | 09:22 PM
jdobeckj's Avatar
jdobeckj is on a distinguished road
Really Rich...
Good eveniing gentlemen..
After a rebuild of my carbs she is running awesome... BUT she is running really really really rich, like saturate my plugs smell fuel out the pipes rich.. I am unsure what to do or what direction I need to go.. any thoughts?
Please
Josh
Old Oct 26, 2012 | 09:49 PM
HRCA#1's Avatar
Dude if she;s really running rich she can't be running awesome. What did you do on the rebuild? If you tell me you installed a jet kit I will point you to Hawk8451's "Carb Setup"
post.
Old Oct 26, 2012 | 09:58 PM
jdobeckj's Avatar
NO jet kit, stayed stock. and she has amazing power in the upper rpm's but idle and acceleration. damn.. no bueno. she is eating fuel like it was going out of style.. as for the "rebuild" I got new gaskets a few cans of carb cleaner and just took them apart- put them back together piece by piece..., new vacuum hoses, tps adjustment to 500 Ohms,7moore7 on the forum and myself synced the carbs last sunday.. they werent too out of wack.
Old Oct 26, 2012 | 10:27 PM
jdobeckj's Avatar
No, no rooting around on the jets.. OK so the mixture screw.. thats the one OUTSIDE the bowls right, I believe there is a little brass cap on them??? how do you remove those caps without destroying them?
Old Oct 26, 2012 | 10:34 PM
saige's Avatar
the boss
there shouldnt be caps on them.it is the little D-shaped screws underneath the bowls.
for a starting point,should be 2 1/2 turns out.
Old Oct 27, 2012 | 08:02 AM
jdobeckj's Avatar
Bowl Pix
I popped off the bowls and started a jet cleaning again.. I am looking for the fuel mixture screw...I am lost I do not see where this is.. can someone point it out Please.. Thanks sooo much
Attached Thumbnails Really Rich...-optimized-carb-1.jpg   Really Rich...-optimized-carb-2.jpg
Old Oct 27, 2012 | 08:42 AM
jdobeckj's Avatar
SUPER COOL. I appreciate the knowledge. SO once I have them out, the (RECOMMENDED) setting from re instillation at sea level..? Again thank you soooo much
Old Oct 27, 2012 | 01:18 PM
saige's Avatar
the boss
these are the screws,should put a notch on it so you can use flat head,which motion pro makes the special tool to get it in there when its on the bike.
the tool is only flat head and not D-shaped.
driven
Sep 16, 2007 12:15 PM
99Hawkboy
Nov 23, 2006 10:44 AM
superhawk22
Oct 2, 2006 04:44 PM
ruf455
Aug 14, 2006 04:52 AM
gwade
Sep 13, 2005 08:38 AM
