R/R switch gone BAD
Old Apr 10, 2011 | 07:11 PM
koth442's Avatar
koth442 is on a distinguished road
R/R switch gone BAD
R/R died No big surprise. I bought my replacement R/R off of a 2006 R1. 5 prongs, yada yada. I looked at the wiring diagram from Tweety's web page and found a similar diagram for the R1. Unless, not only, did I look at the wrong year R1 but also they switched pos/neg pins between years I have the wiring correct. However sometime between reconnecting the battery and turning the key my main fuse blew. Help?
Old Apr 16, 2011 | 05:08 PM
koth442's Avatar
For future reference, either I'm REALLY blind (like, I check several times before and then after) I mis-red the diagram and swapped pos/neg.
Or I was looking at the wrong year R1 diagram. Either way I had switched pos/neg. Bike works great now.
For future reference a 2006 R1 R/R is not a very good choice unless your going to cleverly place the R/R. The 2006 has very long fins which do not fit under the tail of the Hawk. So I had to cut them down.
If you DO end up with an 06 R1 R/R the three pins in the light grey are alternator and are universal. The pos is closest to the alternator pins and the neg is furthest to the outside.
inderocker
Apr 26, 2010 06:44 PM
smittyvtf1
Aug 3, 2009 11:13 AM
smittyvtf1
Jul 7, 2009 12:53 PM
chickenstrip
May 6, 2009 02:51 PM
Mactank
Apr 20, 2008 04:07 PM
