r/r replacement
Old Jul 26, 2012 | 01:54 PM
twist's Avatar
r/r replacement
I've been reading the posts on rectifier/regulator replacement due to oem being less than optimal performer. I am concerned. I just bought this and it only has 18800 miles on it and I'm worried that if I ride it the cct will go or the R/R will crap out, both causing me extensive damage.
I've found this as a replacement for the R/R:
Yamaha R1 rectifier regulator voltage Reg 1D7-81960-00-00 FH012AA
It has the FHO figuration but will it fit under the tail section?
Old Jul 26, 2012 | 02:09 PM
YES! It will.
Visit post #1!!
Here
Old Jul 26, 2012 | 03:54 PM
twist's Avatar
YES! It will.
Visit post #1!!
Here
this is the part
Yamaha R1 rectifier regulator voltage Reg 1D7-81960-00-00 FH012AA | eBay
do I need to modify the seat cowl other than relocate the part? Are the fins too large?
Old Jul 26, 2012 | 04:23 PM
Yup thats one of the gooder ones.
Get some OEM style plugs for it,and some good marine grade 10ga wire, and your all set.
Old Jul 26, 2012 | 04:25 PM
twist's Avatar
there's also this
Ducati - Voltage Regulator Rectifier Combination
(I used to ride BMW)
Old Jul 26, 2012 | 04:32 PM
Originally Posted by twist
there's also this
No, thats not what you want if your looking to upgrade to a better option.
Old Jul 26, 2012 | 04:39 PM
Upland111's Avatar
Here is a picture of the R1 FH012 mounted and wired on my motorcycle, and the old one (off 05') I am holding in front of it for comparison.
You just have to move the blinker relay and CDI unit further rearward and re-attach with tie wraps or whatever mounting configuration that you find suitable to you.
r/r replacement-r1-rr-mounted_compare.jpg
Old Jul 26, 2012 | 04:40 PM
Bandit400man's Avatar
Bandit400man is on a distinguished road
FH012AA has been replaced by FH020AA. An to get either of them to really fit well you gotta dremel the one mounting hole out wider an slide it up a lil...piece of cake tho.
Old Jul 26, 2012 | 04:47 PM
twist's Avatar
thanks! The last one was the hot upgrade for the beemers.
I've upgraded to the superhawk! Might as well use the better parts so I don't have to do it again.
Old Jul 26, 2012 | 04:49 PM
twist's Avatar
Attachment 14407
is there a way to get more air on that thing?
Old Jul 26, 2012 | 04:52 PM
twist's Avatar
I thought I would just gas and ride this thing. I see I'm going to be involved with it intimately after all! I like it! I feel better when I know everything going on under me.
Old Jul 26, 2012 | 05:32 PM
Well Erik, you're right.
Read THIS!
Old Jul 27, 2012 | 01:40 AM
And on the Beemer or Duc, the same upgrade that we do here would work just the same... And would be an substantial upgrade from stock and that thing you linked as well...
Non-Mosfet R/R's tend to fail, it's just a question of how robust they are and how long they last... Over 10 years is unusual, the norm is somewhere 1-5 years depending on riding habits...
Mosfet R/R's typically doesn't "age" with heat cycles, and have no chemical parts inside the component, just solid metal encapsulated in resin, so unless you really abuse them with a corroded wiring system, they have an indefinete lifespan regardless of riding habits... And since they have a heat coefficient at roughly 100C or 212F whether or not you put airflow over them is a moot point... They aren't cooled by airflow unless they reach an internal temperature of above 100C or 212F... Until then, the fins only purpose is to increase mass and surface area for thermal differential cooling, ie the air is cooler than the metal mass...
And trust me, not even in Texas will the R/R reach 100C in normal operation, it would require you to run the bike at redline with no lights or other electrical consumers, for an extended period of time... The engine would sieze up before the R/R overheats...
Plus, they are internally themically limited, ie instead of selfdestructing, they clamp down and shortcircuit the current to ground if they are too hot and cant maintain voltage, ie they will pop the main fuse on the bike, and possibly overcharge the battery, but not blow up electronics...
Old Jul 27, 2012 | 03:33 AM
NH-Raptor's Avatar
The R/R died on my 1999 last Friday. It still had the OEM unit and although this sounds great the bike wasn't used much before I bought it. It had 5K miles on it in 2009 when I found it at a Harley dealership having been traded in for a Buell.
Old Jul 27, 2012 | 03:53 AM
Not being used is as bad to an diode based R/R as being used... Plain and simple, it has about a 5 year lifespan... After that it's a crapshoot when it's going to fail...
Infact the diodes inside, from their original manufacturer has a projected lifespan of 5 years, and most likely 100.000 cycles, as most diodes of that type have... So why should the end product miraculously have a greater lifespan?
Old Jul 27, 2012 | 03:36 PM
twist's Avatar
a riding friend of mine says he used this. The co says it a "shunt" style part.
Buy New Regulator/Rectifier Honda - Super Duty (5-pin) VTR1000F Superhawk (98-05)
same as OEM?
I don't understand it all. What is the difference between shunt and mofset? this is a more expensive part so I'm inclined to go with the R1 R/R. This part bolts right on and uses the same connector.
Old Jul 27, 2012 | 03:41 PM
same as OEM?
Same basic operating function, yes. This is not a checkmark on the correct side of the list, though...
Old Jul 27, 2012 | 05:26 PM
twist's Avatar
I'm really appreciative of this forum and the members willing to share their knowledge and explain it even tho they've most likely explained it more times than they can count. Thank all! My mind was pretty much made on the R1 R/R but I really wanted to look around and look into as many options as I could. So, the 2 main issues for me with this bike, being new to the VTR and all, will be the manual cct and the R1 R/R. That should keep me busy for a while. I want to tackle the most urgent things first and move to the cosmetic stuff. I'd post a pic of my SH but it's mostly stock and you've seen them all before. Still, I'm excited! I still have that silly grin, (went for a spin this morning).
Old Jul 27, 2012 | 06:51 PM
NH-Raptor's Avatar
Well, the R/R issue and the subsequent "rapid turn blinker" syndrome are resolved thanks to previous posts on the forum. I did purchase my new R/R unit from regulator/rectifier.com before reading this from the beginning but it's on the bike and operating. Only time will tell if it was the right place to buy one from. Thanks to all for the information.
Old Jul 27, 2012 | 10:58 PM
The diode type R/R and Shunt type R/R are one and the same... The Diode's shunt the power to ground to regulate the output... Creating heat, and slowly self destroying... Different name, same crap...
Erion_squid
Jun 11, 2008 09:40 PM
willie
May 1, 2007 01:52 PM
CNI Dawg
Feb 1, 2007 08:32 PM
L8RGYZ
Jan 9, 2007 07:41 AM
willie
Sep 15, 2006 10:42 AM
