R/R on a 2003
Old Oct 3, 2008 | 08:23 AM
kev2002's Avatar
kev2002 is on a distinguished road
R/R on a 2003
I am looking at buying a 2003 hawk. I know the R/R and CCT are things to look out for. Is the 2003 R/R good enough or should I replace with R1 unit. I definately don't want to be stranded.
Old Oct 3, 2008 | 09:07 AM
RickB's Avatar
2001 and later will have the better one with the added cooling fins, they seem to hold up much better with much less failures. With that said if you would feel better with the beefier R1 unit go ahead - peace of mind is a good thing.
Old Oct 3, 2008 | 10:31 AM
Condor's Avatar
BANNED IN D.C.
PLease buy my 2003 hawk. I've resorted to begging.
Old Oct 5, 2008 | 11:48 AM
NWbrew's Avatar
NWbrew is on a distinguished road
The newer ones do have cooling fins and are supposed to be more reliable. However, my 2005 went out after only 1800 miles. From what I've heard, it was probably a lemon of a part, but there's really no way to tell from just looking at it. So I agree with RickB, spend a little money and time for some peace of mind.
Old Oct 7, 2008 | 07:00 PM
cal2az's Avatar
Az/Texas Rider
cal2az is on a distinguished road
I have an '04 and my stock r/r is still holding up fine, although I only have 4800 miles on it. Now that ive answered the question, mine better not go out or im going to be pissed...lol!!
Old Oct 7, 2008 | 07:19 PM
Death Cattle's Avatar
****, my '98 had an r/r with cooling fins, but the thing was fairly small, so im sure that was part of the problem. the R1 r/r's are definitely better. they are much larger with bigger cooling fins. i took my bike for a ride after installing an R1 r/r and was able to put my hand on it afterwards, so they defiitely stay plenty cool.
Old Oct 7, 2008 | 10:25 PM
An old fashioned PC heatsink with a 50mm sq. CPU cooling fan bonded & wired onto my 98's OE non-finned VR/R (with heat sink paste btwn back of VR/R & frame), vent holes bored in the lower rear of the seat cowl with corresponding NACA duct for exhaust, along with an intake duct to the VR/R with its scoop located above the Rr MC, and added electrical load of various lights & gadgets to minimize the need for the VR/R to cast off heat has done the trick (knock on plastic) for 8 years and leaves the battery with a 13.18v charge after every ride. But I have obtained an OE non-finned VR/R which I will mate with another OE plug and wires with crimp connectors that I will carry just in case. Heck, I just finally replaced my OE battery out of guilt. Not bad after 10 years and 60k miles.
Old Oct 8, 2008 | 08:41 AM
rbrais's Avatar
My '98 went 10 years and 20k miles before the tiny OEM R/R went. Doing the '01 R-1 swap this weekend. Got an aftermarket for $65. It's definately beefy....looks like the R/R on my Prairie 4x4.
Old Oct 8, 2008 | 10:34 AM
keep in mind that you can only mount these with the top bolt, just so you dont have any surprises during installation. just make it tight, and thats all you need.
Old Oct 8, 2008 | 12:19 PM
CentralCoaster's Avatar
There's a writeup where they had to relocate a relay to mount the R1 unit. I didn't do that. I simply removed some harness tape so I could change the angle of where it plugs in. Used the top bolt, installed insulated spade connectors, and ziptied the wires tightly to keep it from coming loose.
My failed R/R had burn marks around one of the connectors, and the plastic plug was melted. It was not charging. I got a used Honda one from the shop to replace it, but one that was charging at 17volts.
bluedog66
Jul 30, 2007 03:20 PM
selztoad
Apr 24, 2007 01:27 PM
selztoad
Apr 21, 2007 08:04 PM
nuhawk
Mar 23, 2007 04:56 AM
DavidH1172
Aug 26, 2005 01:56 AM
