Question re 954 compression setting
Over the winter, I swapped the forks with a 954 front end and installed new 1 kg springs and RT gold valve. Setting sag and rebound is simple enough at least for base line, however compression is another animal. I've search through a number of swaps but could not find any info. For those that have done this swap, what is the base compression setting that you would recommend? The bike will be used strictly for track days. If it makes a difference, I'm using Michelin Power One tires.
barncat
Aug 20, 2012 07:46 AM
ClevelandSuperhawkRumble
Apr 21, 2005 01:44 PM
