Question for engine builders.
Old Dec 28, 2009 | 08:25 PM
zmaniv's Avatar
When I torque down my rod bolts to check the oil clearance, can I reuse the old rod bolts then replace with the new ones once I have the correct bearing selected?
Old Dec 28, 2009 | 09:05 PM
autoteach's Avatar
replace, they are a torque to yield bolt, so they get stretched
Old Dec 28, 2009 | 09:09 PM
zmaniv's Avatar
So I should use a new set to check the clearance, throw them away when I remove the rod caps to check the oil clearance then if the clearance is ok use a second new set to finish up?
Old Dec 28, 2009 | 10:24 PM
franz125's Avatar
franz125 is on a distinguished road
Use the old ones
Old Dec 28, 2009 | 10:28 PM
killer5280's Avatar
Originally Posted by franz125
Use the old ones
That's what my common sense tells me, but of course this advice is worth exactly what you paid for it.
It shouldn't make any difference in clearance with the old rod bolts.
Old Dec 28, 2009 | 10:52 PM
autoteach's Avatar
Sorry, I didn't read that clearly. You will not have to torque those to full torque to check clearance, and it is a PITA anyway. Got 30-40ft lbs with the old ones to check you clearances. Use new ones when you put it back together.
P.S. I shot my mouth off without reading through your post all the way.
mootsmadness
Sep 11, 2011 10:51 AM
zmaniv
Jan 4, 2010 06:00 PM
Byrdman
Sep 7, 2009 02:02 PM
REDVTR1000
Apr 25, 2008 12:14 PM
cb21983
Apr 11, 2007 08:52 PM
