Question about PAIR. . . Different way to Block?
Old Apr 19, 2011 | 01:43 AM
1down5up's Avatar
1down5up is on a distinguished road
Ok, so i had the airbox off yesterday and i figured i'd do something about the PAIR.
Instead of flipping the reed valves i thought i would just block the intake breather hose that goes from the airbox to the pair valve (used a bolt clamped inside the line). This is how i blocked the PAIR on my GSXR750 (k7) before i had it tuned etc etc and it worked well.
However i actually noticed that now that the hose blocked there is actually an increase in the popping and farting during deceleration. I have Staintune high mounts, not sure on the jetting as i only bought the bike a few weeks ago.
Any ideas?
Old Apr 19, 2011 | 02:51 PM
RWhisen's Avatar
Former Superchicken Owner
Results using methods other than described in the KB section are not guaranteed.
Old Apr 20, 2011 | 03:18 PM
1down5up's Avatar
Cancle That!!!!!!! I relaised i forgot to put back on the little rubber stopper on the vacume line from the front cylinder (most people have a bolt) after syncing my carbs. . . .
Bike doesnt backfire at all now.
In summary, i just plugged the airline going from the airbox to the pair valve ( the one under the airbox on the right hand side of the bike). Everything else is still hooked up, so the vacume line still opens the valve, but no air can pass from the airbox through the valve to either pair reed valve
Old Apr 20, 2011 | 03:52 PM
The PAIR valve is open at zero vacuum and at low to moderate vacuum, up to 21" Hg. It's designed to close off the air flow at high vacuum, over 21"Hg. So, even just sitting there with the bike not running, the PAIR valve is open to air flow.
Why not just do it right. That way you clean up the underside of the airbox, making access to the carbs much easier. You can get the large plugs (caps actually) for the 2 air line fittings on the bottom of the airbox at the auto parts store.
Old Apr 22, 2011 | 06:22 PM
CrankenFine's Avatar
So is it only California bikes that have 2 airbox fittings to plug? My bike only has 1 open port after removing all PAIR plumbing.
ff
Dec 26, 2008 09:30 AM
lynchie
Oct 15, 2008 12:20 PM
CNI Dawg
Sep 13, 2006 07:37 PM
Texassuperhawk
Dec 26, 2005 11:15 PM
CNI Dawg
Nov 16, 2005 10:07 PM
