one tooth off?
Old May 10, 2014 | 07:16 PM
foosfan's Avatar
foosfan is on a distinguished road
one tooth off?
what would the symptoms b if i was one tooth off?
Old May 10, 2014 | 10:46 PM
Uh, there would be a blank spot in the apple where you bit it? the top of you sweatshirt wouldn't line up? Your comb would get stuck in your hair?
You may want to be more specific.
Old May 10, 2014 | 11:22 PM
Remember the LHC at CERN? The black hole sucking the earth into nothingness? Being one tooth off is kind of like that.
Old May 11, 2014 | 01:10 AM
jerryh's Avatar
Lolololol!
Old May 11, 2014 | 02:34 AM
foosfan's Avatar
thnx for nothin gurus
lol
Old May 11, 2014 | 04:25 AM
Maybe even two or three theeth off, but it could be something like this....bike winds to about 3500 rpm then acts like its out of fuel .... if i give alot more throttle it will pick up speed but lucky to hit80 mph......also if itry n keep it at a constant its kind a like morse code rata tat tat tat if that makes sense ......also tots of back fire on decil.......also fifth n sixth i gotta give it lots of fuel......also it will wind out btr with choke on,,.....but that's just a guess.
Old May 11, 2014 | 11:56 AM
cybercarl's Avatar
LOL
1 tooth out wont make too much noticeable difference it depends if it's both cams or one cam etc. A lot of bikes are 1/2 tooth out because of a slightly stretched cam chain which is nothing uncommon. Basically what it would do is advance or retard either cam and change the lobe separation or maybe both cams have been advanced or retarded by moving a tooth in either direction. So effects could be a loss of low down power with a gain in top end power or gain in low down power with a loss at top or a slight loss across the whole RPM range or a slight increase across the whole RPM range with gains or losses elsewhere. Fuel consumption maybe
As standard the timing marks that Honda give us are not all that precise anyway, and the bikes are built with longevity and emissions in mind so there is room for error. If you wanted exact precision then you would have to degree you you cams in.
I would look elsewhere for the solution to your problem. No harm in double checking the timing for peace of mind but you may be 180 out which you wont see as everything will look normal. Start with checking the simple things like the Vacuum and fuel lines.
Joe you almost made me spit my coffee out when I read that post LOL Funny!!!
Old May 11, 2014 | 09:48 PM
foosfan's Avatar
cyber carl thnx for your reply n im sry for my very vague post...... n i have checked timing several times but its hard on the back cyl to see the timing marks but i believe its good n will take your advice n look elsewhere.....again thnx for your insight
tapatio
Jul 17, 2013 07:32 PM
streetfighter996
Nov 26, 2007 02:49 PM
RonVTR
Jun 19, 2006 11:31 PM
whipit
May 3, 2006 07:57 PM
ricksturbo
Sep 16, 2005 12:59 PM
