No speedo.
Old Jun 25, 2013 | 08:42 PM
Mrredline05's Avatar
No speedo.
So the other week the bike died on the way back home from a long ride. The R/R has been replaced with a R1 one. The speedo was working fine up until it died that day. All other gauges still work, and backlights still work, the speedo just doesn't register speed. When i start it the needle moves to 0, but wont go past there. I've tried to search it but haven't really found any threads close to it that doesn't just go straight to being a bad R/R. Any ideas?
Old Jun 26, 2013 | 12:42 AM
Check the fuse for starters... Then check the speedsensor... If those work it's most likely the R/R...
Old Jun 26, 2013 | 05:47 AM
all the fuses are fine, ill have to check the speedsensor, but i just replaced the R/R with a new R1 one, i dont see how it would be the R/R.
Old Jun 26, 2013 | 06:04 AM
Not saying it is the R/R.. but reality is new parts fail, new- used parts fail, new parts installed have an installation error that shows up as a failed part.
Huge diagnostic mistake NOT to look at all components and sub systems that can cause the symptoms your seeing.
It's as simple as a voltage check.. either your getting what you need at the battery, or not. Then you can cross the R/R off the list and move on.
I have had both the Speedo and Tach stop working on me over the years.. Never been a hard part failure..
Each time it was "fixed" by disassembling each connector, cleaning, drying, and using wire dry , then some dielectric silicone on the plug seal..
don't forget the wire connection with screws on the back of the meter housing, and the large multi wire plug there as well.
Old Jun 26, 2013 | 11:54 AM
good deal, ill get it checked out. thanks for the info. I mean its not a huge problem at the moment, just more of a inconvenience
Old Jun 26, 2013 | 12:50 PM
Well... If the R/R is defect, and spiking at 15V+ the inconvencience of not having a speedo can turn into more expensive repairs as it takes out the ECU and CDI, both several hundred dollars worth... Ie, check NOW!
Old Jun 26, 2013 | 04:07 PM
After it died, i chaged the battery then let it set for a few days off charge after riding it again. Its holding between 12.5V-13.2V, and havent seen it drop or rise past that.
Old Jun 26, 2013 | 04:11 PM
That is the battery with engine off?
If so... not what we are referencing.
Start the bike, bring it up to 3k RPM or so and take a voltage reading at the battery.
Old Jun 26, 2013 | 04:13 PM
with the bike off it sets around 12.5V, Engine started at idle is about 12.8V or so, then at 3K RPM it rises to about 13.2V
seaton001
Apr 6, 2007 04:52 AM
xboxxer
Apr 5, 2007 10:13 AM
steener
Mar 30, 2007 04:10 PM
wardo996
Mar 21, 2007 10:20 AM
mikstr
Feb 3, 2007 05:08 PM
