no 6th gear?
Old Jul 31, 2011 | 02:54 PM
shake-n-bake's Avatar
Umm...I'm awesome. Duh...
shake-n-bake is on a distinguished road
no 6th gear?
so i was cruising on the highway the other day and went to shift into 6th and couldnt. only time i hit that gear is when im on the interstate. i just took a trip up to jacksonville last weekend and cruised in 6th the whole time no problems. yesterday, couldnt even get a half a click in. it was acting like it was already in 6th gear but was pulling like 5000 going 90 if i remember right which was just too high for the speed i was going
Old Jul 31, 2011 | 04:05 PM
JamieDaugherty's Avatar
Assuming that you aren't having trouble in any other gear, that's really strange. It's possibly just your shift lever or the linkage is binding up. In the worst case it could be a bent shifter fork. Have you tried shifting into 6th at slower speeds?
FWIW - I use top gear any time I'm cruizing at a constant speed over 45mph.
Old Jul 31, 2011 | 04:56 PM
tried it today going 55 and still nothing. and no other problems in any other gear. thats why i dont understand it
Old Jul 31, 2011 | 05:26 PM
RWhisen's Avatar
Former Superchicken Owner
Try adjusting your shift linkage a bit to give you more throw.
Old Jul 31, 2011 | 05:28 PM
Thumper's Avatar
I rarely ever use 5th or 6th gears (stock gearing), i guess because i live in twisty road central.
Old Jul 31, 2011 | 05:30 PM
Thumper's Avatar
You mean less shifter throw at the tip i hope. More throw will make for less happy shifting. Many changed their throw to 3/4" over all from i believe nearly an inch stock to make the bike shift better in conjunction with the FactoryPro shift detent kit.
Old Jul 31, 2011 | 05:39 PM
how do i adjust it for that? adjust the rod longer or shorter?
Old Jul 31, 2011 | 05:48 PM
RWhisen's Avatar
I don't think he has the pro shift kit or at least he didn't mention it.
Loosen the jam nuts on your linkage rod and rotate until you see your shift lever move up. Make small adjustments, perhaps a quarter of an inch at a time.
Old Jul 31, 2011 | 05:53 PM
Thumper's Avatar
Yep, just mentioning it was an available option in the past that help my VTR (especially)1st to 2nd shift much more solid.
Old Jul 31, 2011 | 06:51 PM
I suppose I would try putting it up on a swingarm stand and, with the engine off and the clutch pulled in, spin the rear wheel and try to shift it into 6th by hand. Sometimes doing that helps you to "feel" what is happening better.
kardiac996
Jul 18, 2012 06:24 AM
salmanilla2000
Feb 25, 2012 01:24 PM
speedkelly@aol.com
Feb 1, 2012 04:26 PM
Zolatoi
Aug 26, 2009 07:17 PM
AJG101
Mar 7, 2009 07:18 PM
