New front brake rotors?
Old Jul 10, 2014 | 10:29 PM
Hopey's Avatar
Hopey is on a distinguished road
I need new front rotors and want to buy new ,anyone got any best bang for the buck sugestions?
Old Jul 11, 2014 | 08:45 AM
ren's Avatar
ren
I would love to hear opinions on this as well
Old Jul 11, 2014 | 10:44 AM
rick's Avatar
rick is on a distinguished road
I will look at EBC or Galfer.
Old Jul 11, 2014 | 01:05 PM
Wicky's Avatar
My original OEM disks lasted for 30,000 miles performing fine, so replaced them with Honda ones.
Old Jul 11, 2014 | 02:32 PM
J-zerby's Avatar
J-zerby is on a distinguished road
I can't testify to the life of the OEMs as I'm the 2nd or 3rd owner and the bikes got about 42k on it. They've got plenty of meat however they are slightly warped which is bothersome when getting on the fronts with anything more then a slight pull. I have been looking at the EBCs with the square-drive pins and they sound pretty good as they resist warpage. Price point is decent compared to everyone else, cheaper than OEM too.
Old Jul 11, 2014 | 02:40 PM
rick's Avatar
confirm with dial guage if the rotors are truly warped or just glazed before spending money on the replacement. Some times the bottuns can get stuck and feel like warped rotors. I'd try to confirm the buttons are not and the rotor still floats in the carrier too. I had this happen on an f4i.
Old Jul 11, 2014 | 04:07 PM
Pad material transfer to the rotor often causes a grabby, "warped" feeling to brake action.. As suggested above, confirm with a dial indicator the rotor is actually warped.
After that.. EBC lites or OEM is where Id look to
Old Jul 11, 2014 | 09:16 PM
Hopey's Avatar
Pad transfer material?Should be able to be removed?If so with scotch brite or steel wool?
Old Jul 11, 2014 | 09:44 PM
Yes it can come off
i use these
Roloc Brake Rotor Surface Conditioning Disc Refill Pack, 01411 - Shop3M
in an air motor
Old Jul 11, 2014 | 09:48 PM
Hopey's Avatar
I'll give it a shot! Thanks
Old Jul 11, 2014 | 10:33 PM
If you want to ease the job use the 3m paint removal wheel available at depot. I have the set of rolocs but they take way longer than the wheel (same company, ones just beefier).
I agree you should check thickness. The minimum is stamped on the rotor itself.
You need to remove the front wheel and flip the rotors to get the other side (FYI).
Also, take the pads out and check them for glazing. Sand them with like 100 grit paper (put the paper on a flat surface and slide pads over it in circles). Do this til the surface looks dull & uniform.
I like galfer rotors over ebc. They tend to be thicker and give better feel. (I have used both brands).
JoedresVTR
Dec 5, 2009 04:50 PM
kai ju
Sep 19, 2009 09:11 PM
niteridder64
Sep 9, 2009 05:29 PM
Hotbrakes
Mar 21, 2009 04:17 PM
