NEED help with wiring!
Old Feb 23, 2013 | 06:09 PM
sneeze's Avatar
sneeze is on a distinguished road
so im in the gritty part of my street fighter build. ihave everthing apart ready to rock! As I am test wiring the bike back togther i have come across the issue that in order to eliminate my guages i need to some how bypass the guages but still have my tail light and other things that are on the same circuit..i intend to later on have upright bars and then install a small aftermarket gauge set up but for now i really want to ride kickin it old school. figure wind blast means im going to fast .. good enough .. So cal cops dont care as long as yer around 85 or less please HElp! my v8 audi will empty my wallet in days commuting...
Old Feb 23, 2013 | 06:43 PM
RWhisen's Avatar
Former Superchicken Owner
You won't get that much better mileage on a Superhawk!!
Navigate to Tweety's page and open the wiring diagram:
Tweety's Wild Thinking
Old Feb 23, 2013 | 06:58 PM
sneeze's Avatar
thanks forgot to mention mine is a 03.... his diagrams are for a 97--2000.. thanks for the reply though..
Old Feb 24, 2013 | 08:14 AM
Jack Flash's Avatar
Well take off, eh.
https://www.superhawkforum.com/forum...-manual-11365/
'01 to '05 wiring diagram is at the end....
Old Feb 24, 2013 | 11:49 PM
Tailhooker's Avatar
Tailhooker is on a distinguished road
Where does it go
When I got my hawknback from valve adjustment I found an unconnected connector. On page 50 fuel it is circled cannon type plug where does it go? Everything seems to be working
Old Feb 25, 2013 | 04:29 AM
The only differences to the newer bikes are the connector at the gauges being a single one, instead of two... Other than that they are 100% identical... And since wire colors match, it's not hard to "translate"...
Old Feb 26, 2013 | 09:09 AM
cybercarl's Avatar
It would be easier to identify if you posed a pic.
[edit]ignore that I just seen the other thread{/edit]
smokinjoe73
Jun 1, 2012 02:23 PM
WAYNEHAMMER
Jan 30, 2012 07:59 PM
YellaKawi
Apr 1, 2009 09:18 AM
Texassuperhawk
Apr 29, 2007 06:26 PM
Texassuperhawk
Oct 14, 2006 04:43 PM
