Need help setting up suspension for lightweight rider
Old Jan 12, 2011 | 07:31 PM
flyinbrian24's Avatar
flyinbrian24 is on a distinguished road
I need advice on how to set up my suspension for my weight. I weigh 135lbs ready to ride. What wght is my stock suspension set for? I have a Bone stock '98 VTR 1000f. I'm planning to do trackdays this Summer with the Midwest Cafe Racers Association at Gateway International Raceway near St louis,MO. Any input on tire selection would be helpful too.I currently have Pirelli Diablo Corses on the bike now.
Old Jan 12, 2011 | 07:47 PM
Thanx GS man
Old Jan 14, 2011 | 09:43 AM
JamieDaugherty's Avatar
More accurately, the stock VTR suspension is ideal for the following:
Forks - negative 15lb
Shock - 160lb
That's right, the stock springs aren't even good enough to handle the bike alone! Getting proper springs on the bike would be an excellent place to start. If you plan to do much more track time with the bike then making some upgrades to the damping would be suggested.
Gateway is neat, just watch out for that banking! The infield section is fun.
Old Jan 14, 2011 | 03:27 PM
Not to thread jack, but where would progressive rate springs be best applicable? Cause my mechanic put them in my Shadow 600...
Old Jan 15, 2011 | 07:24 AM
Actually the forks in the VTR are old tech... They work very well with progressive springs on the street... Just not the stock springs...
A progressive spring will soak up small bumps better than straight springs that have no wiggle before they start to compress...
But yeah, progressive = comfort, straight = performance... I just don't think it's quite as clear cut and polar as you expressed it...
Old Jan 15, 2011 | 08:42 AM
Although the stock springs are wound with two different coil pitches, they are not progressive. If you investigate them closely you'll find that the two piches actually reach solid height at the same load. That means there is no progression of rate.
Progressive springs are too soft over smal bumps and too stiff over larger ones - the worst of both worlds. Straight rate springs out perform them in all applications including cruisers!
Old Mar 15, 2011 | 09:59 AM
archaicguy's Avatar
Hell I thought Gateway was totally closed. I know there is no drag racing there this year, I was looking forward to getting out there again this year. All other sponsored racing is done for too.
Old Mar 15, 2011 | 06:39 PM
I heard that too. It's a shame because I actually liked that track.
Old Apr 29, 2011 | 09:57 AM
At the time I wrote that post I wasn't aware that Gateway was closed.At our last club meeting the rumor was that it might be open again in july under new ownership.If it does,The MCRA will do everything in our power to put on track days again.
bostonhawk
May 11, 2013 07:43 AM
Blueracer
Apr 20, 2010 04:04 AM
mikstr
Jan 10, 2010 06:10 AM
mikstr
May 6, 2009 05:51 AM
