Need help with bearing selection
Old Dec 18, 2009 | 09:34 AM
zmaniv's Avatar
It looks like Honda dropped the color code for the main journal and crank bearings. They list them now as A,B,C,D & E. Manual lists them as green, yellow, blue, brown and black.
Anyone know what they are supposed to be?
Old Dec 18, 2009 | 03:36 PM
RCVTR's Avatar
Martin,
I don't think they dropped the color codes - I could be wrong though.
The crankcase has two letter codes stamped in it adjacent to the main bearing bores. One is for the left bore, the other is for the right.
The crankshaft has a letter and a number, on the left and right counterweights. The number is for the main journal, the letter is for the rod journal.
The con rods have a number (or are supposed to, mine did not).
To select main bearings, take the letter from the case and the number from the crank (left and right). Use the table in the manual to select the color. Same thing for the rod bearings.
From there, I think you can look up the part numbers for the bearings, based on the color code.
I hope this is what you are looking for.
Old Dec 18, 2009 | 03:45 PM
zmaniv's Avatar
Hey I found out what I need, Ronayers does not list them by the color codes only ABCDE.
I pulled up the bikebandit.com website and they list the colors in parenthesis along with the honda lettering.
A is the blue bearing
B is the black bearing
C is the brown bearing
D is the green bearing
E is the yellow bearing
Hope this helps someone in the future.
Hey mods how about adding this the the knowledge base.
Old Dec 21, 2009 | 10:04 PM
shayne's Avatar
Originally Posted by RCVTR
Martin,
Yep, you gotta use both to get the right bearings.
Old Apr 16, 2012 | 08:47 AM
zmaniv's Avatar
Mods can we sticky this. I had to search for it again. Glad the forum is here
Old Apr 16, 2012 | 08:55 AM
Don`t need no stinkin' bearings
CruxGNZ
Dec 27, 2013 12:48 PM
GlockPointer
Dec 20, 2011 07:29 PM
YellowBird
Jul 5, 2008 09:56 AM
nuhawk
Oct 11, 2007 04:53 PM
cscrawford
Sep 7, 2007 08:43 PM
