Main Air Jet size???
Old Mar 4, 2012 | 04:33 AM
chemomche's Avatar
chemomche is on a distinguished road
Hi, I am trying to build DIY Flo-commander, but i need to know what is the exact size(in mm) of the main air jet
the center jet of the pic
i got a precisious aif flow control valve but it is 1,5mm
but i think it is too small for the purpose, so i may use it for the pilot circuit which is smaller
i can get 2 or 3mm, but need to know what the MAJ size is before make up my mind
i will not double the size of the MAJ because the two carbs will not suck the air at the same time so the end hole will be the air that each carb will get
Old Mar 5, 2012 | 02:17 AM
chemomche's Avatar
and f someone that has a flo-commander can tell what si the size ot the tubing and the adapters, i will be very gratefull
Old Mar 15, 2012 | 02:06 AM
chemomche's Avatar
Anyone?
Old Nov 28, 2012 | 12:05 AM
chemomche's Avatar
still waiting
Old Nov 28, 2012 | 06:32 AM
comedo's Avatar
I think mikstr uses a Flo Commander on his VTR. Perhaps he can help you.
Old Nov 28, 2012 | 07:56 AM
Upland111's Avatar
I have a FC and currently have my airbox off while doing some work. If I think of it I will try to get some measurements tonight when I get home and report back tomorrow.
Old Nov 28, 2012 | 09:17 AM
chemomche's Avatar
Upland111, thanks
that would be great
Old Nov 28, 2012 | 08:13 PM
Upland111's Avatar
Ok. My eyes are getting old but these dimentions are P.D.C.
Tubing ID=5mm
Tubing OD=7mm
In my opinion you can probably find better tubing at your hardware store than is supplied, but...
Main Jet Adapter Length=21mm
Main Jet Barbed Portion = 9mm
The adapter OD over the main jet diameter is about 7mm.
The adapter...Kind of blurry pics
Attachment 14860
Attachment 14861
The Flow commander Body Frt/Bck
Good Luck!
Old Nov 28, 2012 | 08:20 PM
Upland111's Avatar
One More time on the FC Air Jet Adapter Pics
Old Nov 28, 2012 | 11:14 PM
chemomche's Avatar
Really thanks Upland111
Old Nov 29, 2012 | 04:44 PM
Attachment 14866
Attachment 14867
To make your carbs less susceptible to side wind gusts and hard braking stalling, do this simple mod (also see superhawk996.net which is Greg Nemish's site) http://www.superhawk996.net/stumbleafterbraking.JPG
RoadManiac
Aug 9, 2013 04:26 PM
RCHAWK
Jul 2, 2013 05:49 PM
3amta3
Jun 22, 2011 11:19 AM
Jens_denmark
Jun 22, 2010 11:50 PM
Anto
Jul 14, 2008 03:15 AM
