Just a friendly reminder...
Old May 27, 2008 | 10:22 PM
sassage's Avatar
...change your brake/clutch fluid.
I just recently got my 2000 Shawk & changed the brake and clutch fluid...it looked like the color of Coke.
process was easy with the help of a Mityvac.
took it around the block a few times and noticed a HUGE difference
Old May 27, 2008 | 10:47 PM
Gregw's Avatar
Good call. I had some new lines made up today. Gotta take one back, it's about an inch too long. So I should be able to put new fluid in tomorrow. Also put some engine ice in on Sunday. Overflow tank was pretty nasty.
Old May 27, 2008 | 10:48 PM
sassage's Avatar
I'm looking to go to engine ice as well pretty soon...get it local or find any good prices online?
Old May 27, 2008 | 10:56 PM
Springbubba's Avatar
Uhhhhh..huh.huh..Member..
Literally just got done with my brake fluid! Mine was pretty dark. Thank goodness for the Mityvac! Super easy. I need to go read about doing the clutch fluid....
Old May 27, 2008 | 11:12 PM
sassage's Avatar
same thing, just as easy
Old May 27, 2008 | 11:41 PM
Gregw's Avatar
Just local. Since I had the fairings off I figured I'd get it done.
Old May 28, 2008 | 01:44 AM
RK1's Avatar
RK1
Something like the Mityvac would be a big help if you're replacing the lines, but if you're just bleeding out old fluid as you pour in new, doing it the old fashion way is still a one man job and only takes a few minutes.
Also, if the 1-2 shift is notchy and you haven't changed clutch fluid in a few thousand miles, doing so can make a big difference.
Old May 28, 2008 | 12:59 PM
Pimpsterbim1's Avatar
JAMES
i just did mine, it also was the color of coke, and had a ton of crap in the reservoir... but i didnt realy notice a difference... my rear brake still feels near usless (pads are good)..
Old May 28, 2008 | 04:07 PM
VFR79's Avatar
Rooster Wolf
VFR79 is on a distinguished road
Or Speedbleeders. They're a cinch to install and the one man job gets even easier!
JPP
Aug 6, 2010 12:32 PM
8541Hawk
Jun 2, 2010 08:40 AM
j shizzy wizzy
Apr 23, 2010 03:01 PM
Chuey
May 15, 2007 10:51 AM
superhawk22
Jan 21, 2006 12:48 PM
