just don't understand
Old Feb 24, 2009 | 02:16 PM
dickard37's Avatar
dickard37 is on a distinguished road
i did the carb sync ,ran it around and it ran GREAT ,then we got some cold rain and snow (in so.cal. can you beleive it )so it sat for a few days ,,now it's beautiful and i went for a ride ,,and BAM ,there's that annoying spit .hiccup ,fart thing ,always at right around 3k. rpm ,,, i just don't understand ,,,soooo frickin' annoying .........Guess i gotta clean the carbs ,,dang it all to heck ,, But i had her to 140 on the sraights any way
Old Feb 24, 2009 | 03:07 PM
trinc's Avatar
the cold air could have leaned it out just enough... next time pull the choke out a little bit & see if it's better.
what is your jetting set at ?
tim
Old Feb 24, 2009 | 03:17 PM
did water get in the gas, or plug the vent tube?
The tank vent tube needs to be moved or cut at an angle otherwise when the bike gets wet it sits in a pool of water and then the tank can't fill the carbs well and you get those exact symptoms in the wet.
Old Feb 24, 2009 | 03:21 PM
MC Leather's Avatar
MC Leather is on a distinguished road
Did you plug the TPS back in?
Old Feb 24, 2009 | 03:43 PM
Shim your needles to richen her up a tad.
Old Feb 24, 2009 | 03:44 PM
dickard37's Avatar
i just got the bike maybe 7mos. ago ,so i havn't taken the carbs off to see if it's been jetted or not ,,i have pulled the choke out just a little and it does seem to do a little better ,but then the idle drops too low almost to the point of dying ,i just had to change the valves out on the front head due to cct failure ,it did hiccup a little before that but now its worse ,,i should've torn the carbs apart then ,,duh !! ,but the bike sat in the garage during the rain so it didn't get wet ,and i didn't unplug the tps ,so no ,i didn't plug it back in ,,,lol,,,
Old Feb 24, 2009 | 05:21 PM
RCVTR's Avatar
What Greg said.
It soundslike the classic 3k RPM hiccup fart stumble.
Aftermarket exhaust?
Old Feb 24, 2009 | 06:24 PM
dickard37's Avatar
yeah ,,two bros. carbon fiber
Old Feb 24, 2009 | 06:31 PM
996SSVTR's Avatar
Nose Picker
996SSVTR is on a distinguished road
Mine had the same problem, after about 10 hour of trying to find the problem, I took it to the shop they re-jetted the bike and now it runs great. all for $255.00. And all of that just because I decided that it would be nice to have a K&N filter.
Old Feb 24, 2009 | 06:51 PM
jbaxx's Avatar
Honducati
Originally Posted by RCVTR
What Greg said.
What they said. Lean 3k classic symtom.
Old Feb 25, 2009 | 07:45 PM
Mr Toad's Avatar
Deus vult!
Mr Toad is on a distinguished road
I rode my VTR later into the end of the season than I usually do. The colder it got, the crappier she ran. Just above freezing it was almost unrideable without the choke engaged. I'll be shimming the needle before it's back on the road. It's always had the 3k stumble, but I like the pair-induced rumble when I back off the throttle. One of the most appealing things about this bike is all the different sounds it makes at different throttle settings!
sneeze
Aug 12, 2014 07:14 AM
Old Yeller
Jul 18, 2011 07:22 AM
FinalBoss
Jun 23, 2010 10:34 PM
pigwings
Nov 27, 2009 10:37 AM
j shizzy wizzy
Jun 21, 2009 05:38 PM
