Issue with steering
Old Nov 20, 2010 | 11:07 PM
babyhawk's Avatar
Toddler Member
babyhawk is on a distinguished road
Issue with steering
I just recently got my Honda VTR1000F and I'm have some problems with turning left or right. The bike is very stubborn when i try to turn. the front end also shakes a little when i force it into a turn. I'm fairly light, about 125 lbs, I'm not sure if that could be an issue...or i may just be a noob rider. I also have a scott's steering damper on the bike, i adjusted it a little but it did not really help that much. Any input would be nice, thanks.
Old Nov 20, 2010 | 11:25 PM
Could either be the damper or the head bearings. First, try removing the damper and see what happens.
Old Nov 21, 2010 | 06:40 AM
RWhisen's Avatar
Former Superchicken Owner
Step 1.
Check tire pressures. Check to see if it is easier to turn front wheel.
Step 2.
Check for brake line interference on the front forks as you turn the handlebars.
Step 3.
Turn the little **** (one with pointy indicator) on the damper counter clockwise to see if it gets easier to turn the front wheel.
Step 4.
Remove damper. Check to see if it is easier to turn front wheel.
Step 5.
Lift front end to check steering bearings.
Old Nov 21, 2010 | 06:57 AM
nath981's Avatar
welcome to the forum babyhawk and congrats on your new bike!
tell us more about your mechanical abilities.
Old Nov 21, 2010 | 10:14 AM
Sounds like worn tires with low pressure. The bike is sensitive to worn tires. Beyond that the stock ball bearings in the steering head are prtty wimpy & should be replaced with tapered rollers. What is the hieght of the fork tubes in the triples & how much preload is on the rear spring? These can throw off geometry to cause this.
Old Nov 22, 2010 | 11:53 PM
BBB's Avatar
BBB
Good Root
BBB is on a distinguished road
Originally Posted by RWhisen
Step 1.
Step 2.
Step 3.
Step 4.
Step 5.
You changed from turning handlebars to turning the front wheel, even I was wondering what effect the damper would have on the front wheel?
Just having a dig, not criticising.
Good stuff.
BBB
Old Nov 23, 2010 | 07:09 AM
nath981's Avatar
after re-reading your post, I realized that you stated your a "noob rider". This reminded me that when I switched bikes with a new rider friend, he commented on the front end of my superhawk shaking, and what we figured out was that he had a death grip on the bars, a common mistake for new riders.
Keep a light grip on the clip-ons except to input countersteer, and then lighten-up on the grips again and see how that feels.
Old Nov 23, 2010 | 06:11 PM
RWhisen's Avatar
Any resolution on this? Did airing up the tire or decreasing the damping work?
Old Nov 23, 2010 | 08:39 PM
babyhawk's Avatar
Toddler Member
thanks for all the advice guys. maybe i do have a death grip when i go into turns. i've been using my suzuki gs500e and i turn the same way i do with the superhawk. the front tire does have some wear though and i think that causes the bike to shake around 55mph when i slightly let go of the handlebars. that could also be the cause of the turning?
Old Nov 23, 2010 | 09:16 PM
ranchomice's Avatar
And after you remove it, sell it to me real cheap!
Welcome, good luck.
Old Nov 24, 2010 | 04:14 AM
nath981's Avatar
that shaking at 55 is likely wheel balance and/or irregular tread wear. I wouldn't get too casual about throttling hard out of turns/at lean with that front tire.
The death grip will have varying effects on diff bikes and tends to be less severe on light bikes. Regardless, it is a bad habit that should be eliminated as it only serves to destabilize...
Old Nov 24, 2010 | 07:14 AM
mhaisten's Avatar
Wrench Bender
My SH hates it when the tire pressure gets low. The rear goes from 40 psi cold to mid twenties in about two weeks. The front stay up pretty well. I can tell in the first turn when the pressure is low, it won't turn!!
Old Nov 24, 2010 | 03:31 PM
nath981's Avatar
you're a lot more casual about tires than me for sure. I push down hard on both tires so often i can detect a few lbs of pressure by feel.
I don't know what tires you have on, but I haven't ever had a tire lose that much pressure that quickly. Check the bead alignment, i.e., the line next to the rim edge should be perfectly even all the way around the rim on both sides. Or you have a slow bead or tread leak you can detect with a soapy solution.
Old Nov 24, 2010 | 06:24 PM
Babyhawk, I taught Vocational Automotives to hundreds, if not thousands, of students from Little Saigon from 1975 through 2008. Welcome to the Forum.
Like said above, check tire wear, pressure and balance, as well as the steering head bearings. This bike is easy to ride, but if you are a new rider, taking the MSF (Motorcycle Safety Foundation) class would help a lot. You'd learn countersteering, braking and turn initiation along with other skills and street survival tactics. I weigh 155, and mine handles great. Go easy until your skills improve, and ride safe.
I only ever had one student from Little Saigon who rode a motorcycle. He was about 19 or 20 years old at the time, and that was about 25 years ago. He rode a Kawi KZ650.
kickerfox
Jun 10, 2012 03:04 AM
Galaxieman
May 29, 2012 11:58 AM
Hollow Man
Jun 5, 2007 08:26 PM
Autarkic
Apr 5, 2007 02:51 PM
