installing my Scorpion slip-on
Old Jun 7, 2010 | 02:10 PM
DaNewKidd's Avatar
DaNewKidd is on a distinguished road
Hi guys,
I'm putting on a pair of Carbon Fiber Scorpion exhaust I picked up off craiglist (for $100), the guy who sold it to me gave me a tube of Permatex RTV silicone Hi temp and said I should use it as a seal for the pipes...is that really necessary? Should I just install them and give it a good clamping and if it leaks THEN i try the RTV gasket seal?
Thanks for your input!
Old Jun 7, 2010 | 02:46 PM
There should be a gasket with your OEM exhaust, if your new system needs it, reuse it unless it is toast (with no goop) if it is toast, pick up a new one:
http://www.ronayers.com/Search/N/687...-750/Source/HO
I don't recall if I reused mine or removed them, but either way I didn't need to buy new ones or use any goop when I installed my MIGs.
Old Jun 7, 2010 | 03:10 PM
Your understanding of it is absolutely correct... Use goop only if neccessary to stop leaks than can't be plugged any other more appropriorate way...
Old Jun 8, 2010 | 03:12 AM
ripvanwinkle's Avatar
aka sirch345. vtr1000.org
ripvanwinkle is on a distinguished road
I have Scorpion hi-level race can's (no baffles straight through) on my bike, they are stainless steel not carbon. I bought mine about 8yrs ago, so the link pipes my be made different now, but without using a joint sealer mine will pop and bang on the overrun like mad. It's OK for at first, a bit of a novelty even, but after a while I got fed up with it. My Scorpions are not designed to be used with the original joint gasket.
Old Jun 8, 2010 | 10:15 AM
zubzero's Avatar
zubzero is on a distinguished road
I have also scorpion slip-ons and they are not ment to be used with the oem joint gasket. mine are stainless steel round and i bought them last winter. payd 300€ for pair of new ones. I tried to put the origal gaskets but they don´t fit, the fitting of the pipes is too tight to but any gasket in there. Friend of mine used some silicone based sealant that stands for 340celsius heat or so, i just let it leak for while. After few runs its blokked by it self
Old Jun 8, 2010 | 01:16 PM
DaNewKidd's Avatar
shieeeeeeeeeeeet while installing the slip ons i stripped the allen bolt that holds the lower pipes to the foot peg...now there's just a round hole in the allen and the hex nut behind is stripped also.
FUUUUUUUUUUUUUUUU
Old Jun 8, 2010 | 02:59 PM
spladle160's Avatar
left hand drill bit and easy out
Old Jun 11, 2010 | 10:14 AM
DaNewKidd's Avatar
i ended up slamming another allen key one size up and it made enough grip to wrench it free...the scorpion exhaust is on yippeeeee
but right away i noticed smoke coming from one of the joints...not sure if it's exhaust leak or the WD-40 burning off...the smoke only seems to come once the pipes get hot
and what a sound! bwaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa!
Old Jun 12, 2010 | 08:25 AM
Congrats. The smoke is probably **** burning off. Take a strip of toilet paper and move it around the joint. You'll see the paper move before you'll feel it on your hand if there's a leak
8541Hawk
Aug 16, 2012 07:40 AM
supertwinSH
Jun 23, 2010 03:11 PM
Pimpsterbim1
Feb 16, 2009 01:52 PM
Pimpsterbim1
Feb 6, 2009 03:26 PM
gpz4jp
Jan 21, 2007 10:19 PM
