Ignition Not Advancing...???
Old May 13, 2008 | 10:41 PM
In my long and very annoying quest to stomp out the gremlin in my bike I decided to run some test's on my TPS. History
As per the Honda service manual, if you start the bike with the TPS unplugged then keep the rpm's above 3,500 and plug the TPS back in the rpm's should rise. How much I do not know... but mine do not rise at all.
I've tested for continuity from the TPS coupler back to the converter unit and that came back good.
I calibrated my TPS to 500ohms dead nuts (from 860ohms), no difference.
I swapped converter unit's and ICM from a good running 2001 VTR, no difference.
I swapped carb assemblies from my buddies VTR (TPS and all), no difference.
I took it for a short ride with the TPS plugged in, then stopped, turned the bike off, unplugged the TPS then started riding again.... it made absolutely no difference. How much of a difference should there be?
Does it sound like my ignition is not advancing for some reason... is there something I'm forgeting to check?
Video...
Old May 14, 2008 | 06:36 PM
I ran a track day with my TPS unplugged and never could tell. I think it has very little effect on the way the bike runs.
Old May 14, 2008 | 06:50 PM
Jim TT's Avatar
Jim TT
Advance is for higer RPM and should not effect idle; Ive read the history...have you checked and lubed your throttle cables?
Old May 14, 2008 | 06:55 PM
Throttle cables are in top notch working order.
Old May 15, 2008 | 07:27 AM
TheRezyReb's Avatar
TheRezyReb is on a distinguished road
SWAP CDI'S WITH YOUR BUDDY.
Old May 15, 2008 | 08:43 AM
He's got a '98 so his won't plug into my harness. He is buying a new wire harness soon, so i may lay his new harness over my bike and plug in all the engine connections then use his converter unit and icm and see if that works. I did swap mt icm and converter unit with a set I won on eBay, but it made no difference.
Old May 16, 2008 | 03:13 AM
ripvanwinkle's Avatar
aka sirch345. vtr1000.org
ripvanwinkle is on a distinguished road
inderocker,
I've had a quick look through your history and this thread but I don't see any mention of how the bike runs on the road? Apart from the tick over issue does this problem affect the performance of the engine when riding the bike?
Chris.
Old May 16, 2008 | 10:01 AM
-Cold start is terrible.
-Idle is moderate.
-Take off is good.
-Midrange is great
-Top end is exceptional
Old May 16, 2008 | 12:23 PM
PUSHrod's Avatar
This echoes a problem I had with a built, (big pistons and cams, BUB exhaust and pumper carbs), R 100 RS. I pulled my hair out thinking I had checked everything twice, but I had been in error on three items. The ignition was set too far advanced, the valves were too tight and the throttle cables were binding.
Perhaps apples and oranges, but where is your ignition set and did you check for vacuum leaks?
Old May 16, 2008 | 12:39 PM
RCVTR's Avatar
I'm in the vacuum leak camp. In order for the idle to be high, there has to be air and fuel to burn. If the throttle plates are closed, there can't be air unless it's getting in some other way.
Old May 16, 2008 | 02:31 PM
TheRezyReb's Avatar
Possibly a hole in one of your carb diaphrams?
Old May 16, 2008 | 02:44 PM
I've used 3 different set's of carbs and 2 sets of intake boots.
Old May 16, 2008 | 03:04 PM
RCVTR's Avatar
What is the air cutoff valve? Either I'm forgetting about it, or it was added in later years.
I know on cars, a valve was added to provide air to burn the extra fuel pulled into the engine when the throttle is closed abruptly. My integra had a vacuum actuated shuttle to allow air to bypass the throttle plate until the vacuum dropped. On another car there was a solenoid acuated rod that would briefly prevent the throttle from closing completely for the same reason. It caused the idle to hang briefly for lower emissions.
Old May 16, 2008 | 03:08 PM
I was too, but I've unloaded the better half of propane bottle to try and find one.
Old May 16, 2008 | 03:12 PM
It cuts air to help drop the rpm's. It's a diaphragm in a black housing on the side of each carb.
Old May 16, 2008 | 03:24 PM
RCVTR's Avatar
Are you sure?
Check the actuation source. If it is vacuum acuated it probably opens until the vacuum drops. Emission control.
Old May 16, 2008 | 04:03 PM
Pretty sure...
The micro fiche calls it the "are cut valve assembly"
Old May 16, 2008 | 04:19 PM
RCVTR's Avatar
The throttle doesn't need help to cut rpm.
$10 says it opens to burn unused fuel when the throttle is closed and causes the idle to hang briefly.
I think I misstated slightly. It burns unused fuel, but also prevents very high vacuum which pulls fuel out of the float bowls. so it decreases the amount of raw fuel and burns what is there.
Old May 16, 2008 | 07:49 PM
From ninja250.org:
COASTING ENRICHER - Feeding a Closed Mouth
You're blasting down the road and you see a hairpin coming up, so you close the throttle. This closes the butterfly valve. You and your 400 lb. baby (the bike, not the other love of your life), are still rolling with inertia, keeping the engine revs high. Now it can't get the mixture it's trying to suck in because the butterfly valve is closed, blocking the air flow.
To compensate for this there's an air jet in the lower diaphragm chamber that transfers ambient pressure to one side of the coasting enricher's spring-loaded cut off valve. The excess vacuum in front of the butterfly valve is transferred to a drilling that leads to the other side of the cut off valve. This sucks it open, allowing the pilot jet to feed more fuel to the engine, preventing an overly lean condition. (Pop. Pop. Pop.)
Old May 16, 2008 | 07:53 PM
Also HERE on Page 22.
Old May 17, 2008 | 12:25 AM
http://www.cyclewareables.com/pages/.../aircutoff.htm
"AIR CUT OFF VALVES PREVENT "AFTER BURN" GENERATED WHEN THE THROTTLE IS SUDDENLY CLOSED WHEN THE THROTTLE IS SUDDENLY CLOSED, THE VALVE TEMPORARILY CLOSES THE SLOW-JET PASSAGEWAY---CREATING AN INSTANTLY RICHER MIXTURE AND THUS REDUCES "POP" SOUNDS UPON DE-ACCELERATION"
Old May 17, 2008 | 01:13 AM
Problem -
-Checked cam timing - good.
Not wishing to sound as if I'm knocking your mechanical capabilities here, but only trying to help.
I feel this problem must be something that's been missed, considering all the different things you've already tried!
Can you explain the procedure you used when you checked the valve timing?
Chris.
Old May 17, 2008 | 01:34 AM
No worries...
Checked the RE/RI, FE/FI corresponding to the appropriate flywheel index mark.
Is there another way?
Old May 17, 2008 | 02:25 AM
No worries...
OK. Say you checked the rear cylinder first by lining up the marks, did you then turn the engine over anti-clockwise 450 degrees (one and a quarter turns) until the 'FT' mark lined up to check the front cylinder?
Chris.
Old May 17, 2008 | 08:32 AM
Don't remember how far the turn was, but if your suggesting that the cam timing was checked on overlap, and it looked to be in time, then the bike wouldn't even run.
If I remember right, the rear cylinder fires first then the front fires 180 degrees later... either that or the front fires first but only 180 degrees after the rear.
Old May 17, 2008 | 08:56 AM
RCVTR's Avatar
Ahhh... yes.
I'm forgeting my carburetion fundamentals. The idle/low speed inlet is just upstream of the throttle plate. It sits perpendicular to airflow. High air velocity creates low pressure, which pulls fuel through the pilot jet. Vacuum has nothing to do with it, except that it causes high velocity at the gap above and below the throttle plate. Is there a second port further forward that comes past the idle screw? I think so.
Anyway, now the air cutoff makes sense. My car had an air bypass, but that was for car emissions standards on a fuel-injected car.
However, I still maintain that it is the change in state of the valve that causes the idle to hang, then unhang. I don't believe my '00 49 state carbs had the valve installed, but I think I remember the location on the carb body where they would go. I put a bigger pilot jet in to get rid of lean decel popping.
I would temporarily disable the valve by plugging the vacuum port. MY $10 is still on the table.
Old May 18, 2008 | 01:37 PM
Obviously it's your call, but my advice would be to re-check the valve timing!!
If you do decide to re-check it make sure the cam lobes are facing in the right direction for each cylinder at TDC. Also that the engine is turned over the correct amount of turns for checking the second cylinder.
As I said earlier I feel something has been missed here and you have to start somewhere.
Chris.
Old May 18, 2008 | 07:42 PM
Cam timing was checked back in November of last year, then again in January of this year when I rebuilt the heads. I have enough faith in my mechanical abilities to to be completely satisfied with the results. As the assistant service manager at the local Honda/Kawasaki/Suzuki dealership, I work on bikes, quads and utility vehicles on a daily basis. I feel rather competent with almost all aspects of motorcycle diagnosis and repair... with the exceptional exception of major electrical diagnosis (gremlins ). For me to tear the valve covers off again to check the cam timing would just be like beating a dead horse. It is a very simple procedure that any motorcycle owner would benefit from knowing (i.e. valve clearance check and adjustment). I definitely appreciate all suggestions, just thought I'd give some background info.
Old May 18, 2008 | 08:27 PM
inderocker, I think I know what the problem is. You're running lean at idle. Try putting the #45 pilot jets back in and adjust mixture screws to 2 turns out. Then do a good carb sync. Keep the mains and the needles where they are. Raise idle speed to 1300.
Old May 18, 2008 | 08:41 PM
I'm actually running #45 pilot jets with the mixture screw either 2 or 2.5 turns out. I still get some sputtering on take off. The #42 pilot jets were too lean with the new 178/180 main jet combo. If I remember correctly, the #48 pilot jets seemed boggy plus it died at idle once it got hot, but I'm gonna give those another shot after the memorial weekend ride. I went on a 200+ mile loop to the Tonto Natural Bridge and got 42MPG... A new record for me, YAY!!
