How to replace brake pedal
Old Jun 19, 2012 | 06:36 PM
PeakAnarchy's Avatar
PeakAnarchy is on a distinguished road
Does anyone have any experience replacing a brake pedal.
I removed the three allen bolts holding the lever and footpegs. I loosed the swingarm bolt which let me swing the rearset but it won't come off short of removing the whole rearset - meaning removing the swingarm bolt. The manual suggests removing the bolt when the bike is on a hoist.
The pipes prevent me from swinging the set under the swingarm.
Help.
(Needless to say, my attempts at straightening the brake pedal were short lived, tragic and costly.)
Old Jun 19, 2012 | 07:21 PM
maniac2313's Avatar
maniac2313 is on a distinguished road
Mine is on the nut side undo the nut drive the bolt back a little bit pull it off do what you gotta do put it back... if you dont drive it through the swing arm you dont have to hoist it... be careful and you will be fine... if its on the bolt side you should be able to get enough room doing the same...
Old Jun 19, 2012 | 08:27 PM
It worked! Big thanks!
Old Jun 21, 2012 | 06:16 AM
maniac2313's Avatar
Glad to help!
superhawkfanboy88
Aug 30, 2012 11:38 PM
snowboarding_champ
Jul 19, 2008 04:14 PM
EngineNoO9
Aug 24, 2006 11:45 PM
Blurr
Jul 19, 2006 09:50 PM
MXC
Jun 18, 2006 05:16 PM
