high rpm problem
Old Aug 5, 2007 | 10:18 AM
DRIVEN2MADNESS's Avatar
DRIVEN2MADNESS is on a distinguished road
high rpm problem
ok... here is the problem i am having my bike runs great from 1000 rpm to about 8500 rpm then it seems like it just dies and comes back on like it runs out of gas, kinta lurches on and off it dosnt pull smoothley to redline.. my carb settings are... factory 1.1 kit 190 rear 188 front 50 pilot needles are second position from the bottom im pretty mutch a sea level. my engine set up is... k&n filter ( no oil ) +4 ign advancer yoshimura stage 1 cams and twobros slip ons.. the bike has been doing this for a while i just cant seem to figure it out.. so i am looking for some opinions...
Old Aug 5, 2007 | 10:48 AM
J.J.'s Avatar
J.J. is on a distinguished road
Ummm are you sure that youre not just hitting the rev limiter?
Old Aug 5, 2007 | 10:50 AM
no the rev limmiter is at 10500 the problem starts at 8500.. im thinking the float level is too low...
Old Aug 5, 2007 | 12:03 PM
Sounds to me like a lean problem. Looking at your setup I think your settings are for stock cams, etc. I don't think the float is the problem but could be jets and needle.
Old Aug 5, 2007 | 01:11 PM
it did the same thing with the stock cams too..
Old Aug 5, 2007 | 01:22 PM
to me it seems like the bike is burning all the fuel out of the float boal then the float drops and re fills the boal and the bike picks up again... i had the carbs apart today and everything is clean and the floats move freeley
Old Jun 14, 2008 | 05:27 PM
nwellinghoff's Avatar
nwellinghoff is on a distinguished road
mine does the same thing...usually only when I am going over 60. Feels like its sputtering and wants to die. Did you ever figure out what was causing it?
amhsraptor
Sep 17, 2010 06:25 AM
uchi
Sep 15, 2009 02:11 PM
luv2insanity
Aug 31, 2008 08:05 AM
bob4pres
Jul 25, 2008 10:38 PM
jonlun
Jul 16, 2008 03:54 AM
