High Beam indicator
Old May 15, 2012 | 05:44 PM
MikeMcW's Avatar
MikeMcW is on a distinguished road
High Beam indicator
I was riding the other night and noticed that while my high beam is on the indicator was blinking in and out. The headlight did not dim or change but the indicator ended up going out. I have replaced the RR last year and I am wondering if it is leading to another RR issue or if the indicator light may have just blown. I have not rode it since as I didn't want to get stuck anywhere.
Old May 15, 2012 | 06:05 PM
RWhisen's Avatar
Former Superchicken Owner
I would check the light bulb
Old May 15, 2012 | 07:58 PM
Size:  1.4 KB doesn't sound like anything serious so you are safe to ride it until you replace the bulb or at least pull it out and make sure it's blow or the connection is dirty
Old May 15, 2012 | 08:04 PM
MikeMcW's Avatar
Sounds good. Is this a 3 bolt unhook and remove from the back?
Old May 15, 2012 | 08:17 PM
It's two (2) 10mm hex bolts, one on each side if I remember right but it has been a while....lol. The allen head in the center is fake....
Old May 15, 2012 | 09:48 PM
aja's Avatar
aja
It's 3, the two on the side and one in the bottom. The light is held in by a black boot that the wire runs into. Gently pull that out and it should be a t10 spade bulb.
Tebs
Jun 9, 2013 07:31 PM
uchi
May 12, 2011 03:32 PM
lazn
Jan 9, 2009 08:27 AM
dan
Dec 31, 2006 08:21 PM
