Hesitation and skipping problem
Old Aug 12, 2009 | 08:16 PM
forsfed25's Avatar
forsfed25 is on a distinguished road
Hey guys just got a 99 super hawk fixed up and back on the road for the most part. bike runs great except at very slight steady throtle it will skip. If I give it more throttle it's smooths back out. Like I said it only happens at slight steady throtle when putting around the city. The bike does have slip on aftermarket muflers. Seems like a fuel issue to me but not quite sure what to try first?
Old Aug 12, 2009 | 09:06 PM
These bikes usually require rejetting with aftermarket exhaust. Shimming the needles may help if the problem is only happening off-idle or part throttle. It requires removing the carbs, but is not too difficult.
Do a search on needle shim. There are a number of threads.
Old Aug 13, 2009 | 05:38 AM
forsfed25's Avatar
Ya kinda figured the bike was never re-jetted with the exhuast. I will def look this up and give it a try. Thanks much.
Old Aug 13, 2009 | 07:26 AM
chickenstrip's Avatar
chickenstrip
Balancing the carbs can't hurt, either.
Old Aug 13, 2009 | 10:27 AM
Mr Toad's Avatar
Deus vult!
Mr Toad is on a distinguished road
Shim mod = best $0.10 ever spent!
Old Aug 20, 2009 | 05:51 AM
forsfed25's Avatar
Haha so finally got around to pulling the carbs the other day. I had bought some shims but found out someone had aleady but a jet kit in it with adjustable needles. So raised one needle up a notch, then went to do the other and found that one already in the notch I had just adjusted the other needle too.... They had set the needles up diferent! So left that one alone, put it all back together and bike runs beautiful now. Some people really need to pay more attention to their work. Thanks for your help guys I really appriciate it.
KAB
Jan 5, 2014 07:59 PM
Malice
May 4, 2008 12:47 AM
FullFlavorPike
Mar 11, 2007 10:27 AM
redline76
Jan 21, 2006 12:53 PM
00996rider
Mar 29, 2005 07:40 PM
