HELP!! Putting crankshaft sensor sprocket back
Old Jul 14, 2009 | 04:26 AM
blue firestorm's Avatar
blue firestorm is on a distinguished road
Need help putting the 3 small springs back in behind the sprocket, has anyone done this before? Its pictured in the service manual section 9.0.
Is there a special tool required??
Old Jul 16, 2009 | 04:22 PM
anyone done this job before??????
Old Jul 16, 2009 | 05:44 PM
RCVTR's Avatar
Are you talking about the backlash springs on the crankshaft primary drive gear?
If so, when you put the springs in, the primary drive gear and the thinner anti-backlash gear teeth are misaligned. You will need to rotate the thin gear until the teeth align. There is an alignment hole (maybe 2, for balance) that will line up when the teeth are aligned. Insert a drill bit that just fits the holes, to keep the springs compressed and the gear teeth aligned. Then you can slide them on to the crankshaft and remove the drill bit.
Apocalypse
Jun 14, 2015 09:47 AM
smokinjoe73
Nov 9, 2010 09:39 AM
skoshere
Jan 23, 2009 09:25 PM
comedo
Feb 23, 2008 10:19 AM
divingindaytona
Mar 27, 2005 11:37 PM
