Help! Mystery o-ring gasket
Old May 21, 2009 | 12:34 PM
chickenstrip's Avatar
chickenstrip
Hey guys, I'm putting the front cylinder head back on my bike after having a shop do some valve work. I put the head in a box when I took it to the shop, and now, pulling it out of the box, I've found an o-ring gasket that looks familiar, but damned if I can remember, or figure out, where it goes. I've looked at the manual, and at the micro fiche on Ron Ayers ... but I can't see where it goes.
Is there an o-ring between the head and the block? (I don't think so.) Is there an o-ring between the head and the valve cover?
The gasket is about a 1/2", outer diameter.
Thanks for the help.
Old May 21, 2009 | 12:42 PM
Kendrick's Avatar
The Hypno-Toad
Yeah, there's an o-ring on the center pin/tube between the head and the valve cover.
Old May 21, 2009 | 12:46 PM
chickenstrip
Thanks! I looked but I didn't see a recessed area for the ring to sit in. I'll check that out again.
Thanks again for the prompt response.
hawxter996's Avatar
ole dirty bastard
yup, for the damned pair system.
Old May 21, 2009 | 03:27 PM
Kendrick's Avatar
The Hypno-Toad
It's not recessed it just goes around the metal tube.
Old May 21, 2009 | 04:20 PM
chickenstrip
Yeah, that's what I discovered, that I had been looking for the wrong thing. The o-ring in the middle is kind of a continuation of the perimeter gasket.
Old May 21, 2009 | 05:37 PM
CentralCoaster's Avatar
Yeah, it's sort of a dowel to help locate the valve cover. Oring keeps it sealed.
johnanthony_78
Jan 27, 2014 11:42 PM
johnboy
Jun 11, 2009 08:27 AM
chevy
Mar 13, 2009 09:38 AM
Goontah
Feb 12, 2008 07:44 PM
ClevelandSuperhawkRumble
Mar 24, 2005 12:34 PM
