Help with Idle speed
Old Jan 20, 2006 | 05:47 PM
Randman's Avatar
Moderate-whore
I know I have seen this somewhere on here, but I can't find it now....
What should the RPM's be at idle?? Mine runs right at 1000 at idle....sounds like it should be higher....
TIA....
Old Jan 20, 2006 | 05:51 PM
AZZKIKER's Avatar
1200 rpms. The **** is on the right hand side below the side fairing and inside the frame, you can see it if you peek in there.
Old Jan 20, 2006 | 07:26 PM
Randman's Avatar
Moderate-whore
Re: Help with Idle speed
Cool, thanks for the info, and the location of the adjustment, that would have been my next newbie question I thought it was supposed to be higher than 1000....
Old Jan 20, 2006 | 10:07 PM
jschmidt's Avatar
jschmidt
Spec is 1100-1200. I run mine at 1300 and find it eliminates the clunk-die problem.
Old Jan 21, 2006 | 07:50 AM
Randman's Avatar
Moderate-whore
Yeah, I did see another post this morning that suggest setting it at 1300....Any reason you wouldn't do that??
Old Feb 9, 2006 | 10:35 AM
cb21983's Avatar
cb21983
I had mine set at 1300 and it was to noisy at traffic lights to talk with my buddies. But I don't know if that is a reason you wouldn't want to do it??
Old Feb 9, 2006 | 02:38 PM
JamieDaugherty's Avatar
I run mine at 1000 without any problems. I think rought idle conditions have more to with out-of-sync carbs than anything else. Other out of tune issues can also be factors too.
Jamie Daugherty
http://members.iquest.net/~daugherj
thedeatons
Jun 21, 2015 09:11 PM
Apocalypse
Feb 13, 2015 08:06 AM
seb421
Jun 29, 2009 10:32 AM
VoodooDog
May 16, 2007 01:18 PM
DaxMiddler
Apr 28, 2006 03:22 AM
