Help with Idle speed
I know I have seen this somewhere on here, but I can't find it now....
What should the RPM's be at idle?? Mine runs right at 1000 at idle....sounds like it should be higher.... TIA.... |
1200 rpms. The knob is on the right hand side below the side fairing and inside the frame, you can see it if you peek in there.
Re: Help with Idle speed
Cool, thanks for the info, and the location of the adjustment, that would have been my next newbie question :lol: :lol: I thought it was supposed to be higher than 1000....
Spec is 1100-1200. I run mine at 1300 and find it eliminates the clunk-die problem.
Yeah, I did see another post this morning that suggest setting it at 1300....Any reason you wouldn't do that??
I had mine set at 1300 and it was to noisy at traffic lights to talk with my buddies. But I don't know if that is a reason you wouldn't want to do it??
I run mine at 1000 without any problems. I think rought idle conditions have more to with out-of-sync carbs than anything else. Other out of tune issues can also be factors too.
Jamie Daugherty http://members.iquest.net/~daugherj |
