Help: headlight problem
Old Apr 22, 2005 | 01:03 PM
jschmidt's Avatar
jschmidt
You can examine the bulb. Odds are its bad.
Old Apr 22, 2005 | 01:25 PM
faz's Avatar
faz
faz
It is one bulb, with two lights inside, so one could be gone bad.
Also, did you unplug the connector by any chance? it could be that when plugging it back in, the low bean pin is not connected all the way in or something.
It is not that complicated. I am sure you will find that it is something simple, like a light bulb or what not.
And remember, you can buy regular car type bulb for it. Don't spend too much money on the dealer stuff.
Old Apr 22, 2005 | 01:27 PM
jschmidt's Avatar
jschmidt
Re: Help: headlight problem
Originally Posted by sckomar";p=&quot
I was wondering if there was a chance the bulb could go bad and only work on high, but it seemed like a stretch since it is one bulb. Thanks for the input, anything in particular I should look for with the bulb?
One of the filaments will be broken with a piece hanging down.
Old Apr 22, 2005 | 07:36 PM
superbling's Avatar
How old is the bike and/or does it sit out in the elements alot? The contact switch on the handlebar could be dirty if the bulb is good. H4 bulbs are very cheap and can be bought anywhere (walmart) for a few bucks.
Old May 15, 2005 | 03:24 PM
mikecronis's Avatar
mikecronis
Replacing the bulb is cheap and easy, and can be done without removing the faring. I put in a PIAA SuperWhite and took me 10 minutes or so. Just remove the plug-in part, pull off the black water gasket and unlatch the funky bulb-catch.
Do NOT touch the new bulb's glass parts!!!
CruxGNZ
Apr 30, 2015 09:11 PM
bostonhawk
Sep 1, 2012 08:45 AM
98VTRrider
Jul 13, 2010 08:18 PM
mattvdsande
Mar 16, 2009 11:12 AM
kostavtr
Dec 1, 2007 04:28 PM
