Header touching engine..?
Old Mar 9, 2007 | 10:10 AM
Arctic Fire's Avatar
Arctic Fire is on a distinguished road
Here's a complete new-to-hawk question. Since I bought my bike in the fall, didn't have much time to ride her, or get really familiar with it.
I recently took my D&D's apart, and when I put them back on the bike, no matter what angle i tweak them too, the header pipe touches the engine at the horizontal portion. What is the clearance in this area supposed to be? I seem to remember it being really tight before i started, but never checked if it was actually touching..
Can I just jam a piece of heat insulation down between the two and call it a day? Is it really a problem? Thoughts?
Old Mar 9, 2007 | 10:15 AM
For the visual people...
Old Mar 9, 2007 | 10:39 AM
SlowHAWK's Avatar
Any chance you didn't replace one of the seals on the cyclinder/header mating surface causing it to shift up ever so slightly? (I don't imagine they'd have fallen out when the pipe was off.)
(I hope this isn't common realignment issue as mine is off right now going to Jet Hot!!!)
J.
Old Mar 9, 2007 | 10:45 AM
rossi's Avatar
rossi is on a distinguished road
They do run close about 10mm away from the sump but not that close.
I would put something between the two,just to stop them rubing under vibration but it should'nt cause a problem.
Old Mar 9, 2007 | 11:12 AM
Zedicus's Avatar
Zedicus is on a distinguished road
mines close, i cant get my little finger between the 2. maybe 5mm between them max. and the headers never been off my bike.
Old Mar 9, 2007 | 01:22 PM
Thumbs up
Yeah Rossi, I'm with you, i think i will just get some fireproof something-or-other and wedge it between the two, more for vibration than heat. maybe after I run it for a while with the piece jammed in I will be able to remove it and have my 5 mils. Thanks guys
Old Mar 9, 2007 | 01:37 PM
Darkone22's Avatar
Darkone22 is on a distinguished road
Yeah mine is really close to like 10mm away \looks right
Old Mar 9, 2007 | 06:44 PM
joshn569's Avatar
joshn569 is on a distinguished road
yea mine is about 10mm away, what did you do to make your headers shine like that,. it looks nice
Old Mar 9, 2007 | 08:57 PM
Might want to loosen the header flanges and tweak them out. How about the possibility of ever bottoming out? Maybe bent?
Old Mar 13, 2007 | 04:47 PM
Thanks! Sand paper dry 100 to 400, wet 800 1200 1500 then 2000, then rubbing compund, then stainless steel polish. It actually doesn't take long at all, and if you spray the complicated twisty parts instead of polishing, you can do it in about an hour..
Old Mar 15, 2007 | 03:05 PM
joshn569's Avatar
How long does the shine last>?
Old Mar 15, 2007 | 05:43 PM
I agree and I think the pipe looks too close to the block in front as well. I think it's crooked in the flange.
Old Mar 16, 2007 | 03:21 AM
vtrlvr's Avatar
vtrlvr is on a distinguished road
I hope i can try that polishing job you did on yours this weekend. I hope.. You never ever know when work will call you to come in. (knock on wood). I will let you know how it turns out
Old Mar 16, 2007 | 09:46 AM
Lasts about half an hour, then turns to a beautiful brassy gold colour, still really shiny
mootsmadness
Sep 11, 2011 10:51 AM
Byrdman
Sep 7, 2009 02:02 PM
REDVTR1000
Apr 25, 2008 12:14 PM
cb21983
Apr 11, 2007 08:52 PM
alnames
Apr 3, 2005 09:19 PM
