Glitter in the coolant?
Old Apr 3, 2010 | 01:35 AM
ranchomice's Avatar
Any reason it would appear there was glitter in my coolant? The only thing I can think of is if some type of stop leak was put in at some point. Anybody??
Old Apr 3, 2010 | 05:50 AM
aka Yamadog's Avatar
Glitter...you saying metal particals that are uniform? Or could they be pieces of the water pump? Any oil in the coolant or coolant in the oil?
Old Apr 3, 2010 | 07:04 AM
comedo's Avatar
Unless you've already drained the coolant, remove some with a turkey baster, put it on a piece of coffee filter or something similar, let it dry and figure out what it is.
Old Apr 3, 2010 | 08:29 AM
There's a stop leak product called "Alumaseal" that someone might have put in there. It's just flakes of dry aluminum you pour into the radiator, and it's been around forever.
Old Apr 3, 2010 | 08:46 AM
ranchomice's Avatar
No oil in there. I noticed the coolant level was real low. When I took a flashlight to look in there I noticed what looks just like glitter. This is the bike that had major failure at 1400 miles. Piston replaced, head work etc. I guess my question is, is there a honda coolant product that normally has a shiny meterial in it?
Old Apr 3, 2010 | 04:02 PM
bjorn toulouse's Avatar
Destructive Tester
Short answer: NO
Follow comedo's good advice. Take a sample.
Until you attempt to determine what the "glitter" is, you won't get an idea where to start looking for the possible problem.
If the particles are magnetic, they're steel. Non-magnetic, they're aluminum.
Are the particles uniform in size, or random? Are they flake-like, or chunk-like?
Rex
Old Apr 3, 2010 | 04:30 PM
RK1's Avatar
RK1
I think we have a winner.
Old Apr 3, 2010 | 11:43 PM
ranchomice's Avatar
My first thought is Alumaseal, the only thing is I got the bike with very few miles, don't know what reason it would be there. It doesn't mean it doesn't have sealant in it. It is non magnetic, flake like, almost dust like. It's very small, so small when I "filter it" it is super hard to even see a "shine". I'm just going to flush the system and see what happens. It's running fine, not hot, not cool. The only reason I looked into the overflow with a flashlight is to see how low it was. It was a bit low but I was under the impression that was normal after a change out/major work.
Old Apr 4, 2010 | 07:04 AM
Nope not normal.. If the side cover was replaced or the water pump otherwise worked on,, I'd guess the impeller was set too shallow in the cover and the impeller was / is rubbing against the pump cover.. I've fixed two like this so far where owners tried to replace the water pump seal and did not understand the reason the manual has a very small range for installed height of the impeller.
Old Apr 4, 2010 | 07:29 AM
Stevebis1's Avatar
+1
Or you bike has snuck out to the strip clubs without you...
Old Apr 4, 2010 | 07:33 PM
ranchomice's Avatar
The bike had major work done and the entire case was split. Would the impeller rubbing be audible? That is for sure a possiblility. How do I check it? I have flushed the hell out of the system. Most of it was in the overflow, but it may just appear that way because that is the easiest place to see it with a flashlight. Anybody willing to go shake the bike and look in their overflow tank with a flashlight and tell me what you see?
Old Apr 4, 2010 | 07:51 PM
nath981's Avatar
I would fill it with water, run it a few miles to full hot, drain it and refill with distilled/anti-freeze @50/50 and see what you have after a few weeks. May not be rubbing any more. If it particles recur, then you know you need to act. If not. you're good to go.
Old Apr 4, 2010 | 07:54 PM
nath981's Avatar
+1
hahaha, you mean the old SH may have snuck in a lap dance or two. Knowing mine, it's a good possibility.hahahaha
Old Apr 4, 2010 | 07:57 PM
NAVY8TR's Avatar
I actually was curious about the same thing, not curious enough to start a thread, but still. I changed the coolant in the fall just cause I haven't done it since I owned the bike (11,000mi) and notice the same thing. It was actually really hard to notice. the only reason I was able to see it was cause I had some sunlight. I thought nothing of it, changed it and went on my way. I'm hoping is some sort of alumaseal or whatever they are calling it. What do the masters say?
Old Apr 4, 2010 | 08:43 PM
ranchomice's Avatar
I really appreciate this forum and you guys on it. There are times when panic can be started here but I'm learning to be patient and keep reading : )
I filled, ran and drained it twice with straight distilled water. I also flushed the heck out of the overflow by simply removing the siphon tube and running water through the tank. I'll fill it with coolant tomorrow, burp it, and check it periodically.
It is really hard to see if you're not looking. I ony saw it because I stuck a flashlight in the overflow tank to see how low it was.
Old Apr 5, 2010 | 04:43 AM
You can remove the pump cover and see if it has been rubbing on the cover, or the inverse, if the impeller was set too deep and is rubbing on the case itself (not likely as the installer can see and feel that mistake as it's installed... the impeller will not turn freely)
If the impeller is (was) rubbing against the pump cover.... it's pretty much done what ever damage there was to be done,, the stainless steel impeller cuts through the aluminum cover pretty quick. Both owners I fixed this issue for, had a whirling "rubbing" sound that was the tail tel sign. . the sound and vibration felt at the pump cover was of course the impeller grinding away at the cover.
The fix (if needed on yours.. as your still not sure this is the issue with your contaminated coolant) is removing the side case cover and pump, setting the impeller to the right depth, and if bad enough, replacing the pump cover (on the two I fixed, one was bad, the other had very light marks and was re used) So the parts list is small, side case cover gasket and coolant.
Old Apr 5, 2010 | 05:21 PM
ranchomice's Avatar
Thanks E. mine never made any noise (that I know of) but it does sound like a very reasonable explanation. If that was the case, I think it was slight and it's no longer rubbing. I got it all filled back up and rode today. I'll check every so often to see if it happens again, otherwise, It's all good.
j_frank
Apr 28, 2007 11:40 PM
xecutech
Apr 9, 2007 08:53 PM
EngineNoO9
Oct 20, 2006 09:01 PM
Quebecer
Sep 2, 2006 09:03 PM
faz
Jul 29, 2004 10:58 AM
