Gear shift reversal?
Old Dec 29, 2007 | 05:03 PM
floppyhat's Avatar
floppyhat is on a distinguished road
How do you convert the shifting from standard to race ie 1 up 5 down on a Superhawk?
Thanks.
Old Dec 29, 2007 | 09:31 PM
marmaladedad's Avatar
Hmm?
There is a spline that the shift rod is connected to. You would loosen the bolt holding the arm to the spline, then slide the arm out. Rotate it 180 degrees, then put it back on to the spline.
Check to see that the lever position is where you want it to be, then tighten down on the bolt. Loc-tite is a good idea at that time.
Old Dec 31, 2007 | 09:52 AM
floppyhat's Avatar
That was easy! Shifts great!
Old Dec 31, 2007 | 06:42 PM
Hmm?
Congrats! Free mods are the best.
BTW, isn't Timothy spelled with an "o?"
Old Jan 1, 2008 | 02:31 PM
floppyhat's Avatar
Opps, that's what I get for cutting without checking.
Old Jan 10, 2008 | 07:30 PM
Jim TT's Avatar
Jim TT
The best way is buy a 94 VFR750 (fourth generation) shift lever and bolt it right on, you have no linkage to deal with this set up as it is a direct rear facing lever that fits perfectly. JIM
Old Jan 18, 2009 | 03:59 PM
rahjer's Avatar
rahjer is on a distinguished road
There is a shift lever from a '93 VFR750 on eBay now. Will that work, or does it have to be a '94? It's only $10, but I don't need any more useless crap in my garage if I can help it.
Roger
YTKinWI
May 13, 2011 09:19 AM
vtr996dude
Forum Feedback
Dec 29, 2010 07:55 AM
Skydive
May 13, 2009 11:23 PM
MXC
Jun 18, 2006 05:16 PM
