Gastank removal without spill?
Old Jul 13, 2009 | 08:30 AM
chickenstrip's Avatar
chickenstrip
Okay, I feel really stupid for asking this, but what is the procedure for tank removal without a gas spill? Sometimes I get it off without a hitch, and other times, like this weekend, I get gas everywhere. Does it matter what order the lines come off?
Old Jul 13, 2009 | 08:45 AM
Close the petcock valve and plug the lines leading to the carbs (lift them upwards as soon as they come off to prevent them emptying themselves) and you shouldn't have any spillage.
Old Jul 13, 2009 | 08:49 AM
chickenstrip
Petcock valve? There is no valve, it's just the vacuum tube, right? I thought that I by getting that off first I would prevent spillage, but no ... I'm getting gas out of the tank.
Old Jul 13, 2009 | 08:55 AM
at the very back of the tank (close to the bolt that secures it to the frame), there is a semi-circular steel wheel with a square protrusion, this is the petcock valve. You turn it to the extreme opposite end (forget if it`s CW or CCW) and this will shut the valve.
I think your problem has just been found.....
Old Jul 13, 2009 | 09:11 AM
Thumper's Avatar
yep
8mm wrench i beleive and don't forget to turn it back on after reattaching the fuel lines
Old Jul 13, 2009 | 09:17 AM
chickenstrip
Great! Thanks guys.
Old Jul 13, 2009 | 09:26 AM
trinc's Avatar
after shutting off the valve fire up the bike & run it 'til it dies... that will clear the fuel in the lines ( and bowls ).
note: if your petcock is in good condition, manually turning the valve off is NOT required. pull the petcock vacuum line & run the bike 'til it dies.
tim
doomcookie
Jul 23, 2009 01:19 PM
duran
Apr 24, 2008 06:29 PM
Doc
Aug 25, 2007 04:39 PM
vtrlvr
Feb 8, 2007 07:55 PM
dpenix76
Nov 2, 2006 04:03 AM
